SB small end rod width #330665
05/27/09 07:20 PM
05/27/09 07:20 PM
Q
qkRick Offline OP
qkRick  Offline OP
Q
How 'bout a little help folks. I just purchased a set of KB 742 forged pistons at a smokin' price. All was well until fine print says I need a 1" rod. Can anyone tell me the width of a stock 340/360 rod vs. a magnum rod. Any further input appreciated. I was already thinking Scat, Eagle or K1.
Re: SB small end rod width [Re: qkRick] #330666
05/27/09 07:24 PM
05/27/09 07:24 PM
1.2" & can just have your shop narrow them EDIT yes magnum rods are 1"
Re: SB small end rod width [Re: RapidRobert] #330667
05/27/09 07:36 PM
05/27/09 07:36 PM
Q
qkRick Offline OP
qkRick  Offline OP
Q
Thanks! Are the aftermarket rods also 1" or the stock width.
Re: SB small end rod width [Re: qkRick] #330668
05/27/09 07:43 PM
05/27/09 07:43 PM
I do not know but machining stock rods to 1" is a very painless procedure & is done regularly & does not sacrifice enough material to be a problem so if you are content w your stock rods & are Ok with rebuilding the big end as opposed to some new ones(which I think is a good idea, depends on your intentions) no need to switch just over the small end width issue.
Re: SB small end rod width [Re: RapidRobert] #330669
05/27/09 09:20 PM
05/27/09 09:20 PM
Q
qkRick Offline OP
qkRick  Offline OP
Q
Thanks!
