Synthetic rear end lube bad for race car? #330285
05/27/09 12:45 PM
05/27/09 12:45 PM
mikemotorhead Offline OP
super street
super street
I was told today that I should not be using synthetic lube in my Dana rear. He said that synthetic does not have the ability to protect against the "shock" of a transbrake and heavy loading. Says conventional is much better.This is news to me as I have had synthetic in there for a number of years without issue!
Anyone else heard of this???
Thanks Mike
Re: Synthetic rear end lube bad for race car? [Re: mikemotorhead] #330286
05/27/09 12:55 PM
05/27/09 12:55 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I have only run synthetic in my Dana for 5 straight years now. Zero problems and probably close to 1000 passes. Course I don't use a transbrake, but I don't believe conventional is better in this application.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Synthetic rear end lube bad for race car? [Re: mikemotorhead] #330287
05/27/09 12:57 PM
05/27/09 12:57 PM
So. Jersey
Somerdale Flash Offline
So. Jersey
Thanks Mike
Been using synthetic in both cars with a Dana for years... Thousands of runs with a trans brake.
Never a problem. Pull the cover off and check at the beginning of the season every year. No problems at all.
Re: Synthetic rear end lube bad for race car? [Re: Somerdale Flash] #330288
05/27/09 01:00 PM
05/27/09 01:00 PM
sweden
sshemi Offline
sshemi  Offline
sweden
why would you wanna use syntetic?
Isnt it more expensive?
Re: Synthetic rear end lube bad for race car? [Re: sshemi] #330289
05/27/09 01:04 PM
05/27/09 01:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
a little bit but well worth it imo. never heard anybody say not to use it????? just helps with being more consistent imo. less temp sensitive.
Re: Synthetic rear end lube bad for race car? [Re: sshemi] #330290
05/27/09 01:09 PM
05/27/09 01:09 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Been using Mobil 1 Synthetic 75w-90 for many years in our Dana and so far so good. Plenty of transbrake launches!
Post deleted by Defbob [Re: cl440] #330291
05/27/09 01:17 PM
05/27/09 01:17 PM
Re: Synthetic rear end lube bad for race car? #330292
05/27/09 02:57 PM
05/27/09 02:57 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I use whatever Richmond suggested. I believe 75-90 synpower is whats in it
Re: Synthetic rear end lube bad for race car? [Re: The Avg. Valiant] #330293
05/27/09 04:29 PM
05/27/09 04:29 PM
organ
maximum entropy Offline
organ
i have no idea why, but moser specifically recommended against using synthetic in their rear ends. i didn't bother asking why. i just do as i'm told.
Re: Synthetic rear end lube bad for race car? [Re: maximum entropy] #330294
05/27/09 05:46 PM
05/27/09 05:46 PM
detroit area
moderncylinder Offline
detroit area
mark williams says no synthetic also,, says it doesnt "cling" to the gear as well and std oils
Re: Synthetic rear end lube bad for race car? [Re: Quicktree] #330295
05/27/09 07:53 PM
05/27/09 07:53 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We tried it with our Outlaw car and burned up a ring and pinion. We don't use it now.
Re: Synthetic rear end lube bad for race car? [Re: BobR] #330296
05/27/09 08:36 PM
05/27/09 08:36 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
i think if you run a spool or not
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Synthetic rear end lube bad for race car? [Re: davesmopars] #330297
05/27/09 11:19 PM
05/27/09 11:19 PM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I run Red Line Heavy Shockproof synthetic gear oil in my rear...I think that is the only thing helping out the hard street gears I run in the 8 3/4...T-brake 60' low 1.30's 3358lbs
Re: Synthetic rear end lube bad for race car? [Re: Cudafied] #330298
05/28/09 01:41 AM
05/28/09 01:41 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using castrols synthetic & have so for the past 5 years. we had the diff apart during last season. the diff man said everything was like brand new. even the oil still looked like light colored honey so i poured it back in. synthetic diff oil sure does smell.
