ELECTRONIC IGINTION wire diagram #330166
05/27/09 10:07 AM
05/27/09 10:07 AM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
I have a 71 Cuda small with points wire harness and I want to change it to electronic using the Mopar Performance distributor kit, but I need the wire diagram...
Can some one post the diagram for me...thanks
CHECK OUT MY NEW WEB SITE !
Re: ELECTRONIC IGINTION wire diagram [Re: anlauto] #330167
05/27/09 10:13 AM
05/27/09 10:13 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Alan,
At work and don't have the diagram with me.
It is easy.
The wire harness that comes with the kit uses the plug to the ECU/ 2 dist wire plug / and 1 to ballast and coil the green wire is not used
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: ELECTRONIC IGINTION wire diagram [Re: anlauto] #330168
05/27/09 10:35 AM
05/27/09 10:35 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Re: ELECTRONIC IGINTION wire diagram [Re: VCODE] #330169
05/27/09 11:53 AM
05/27/09 11:53 AM
cataclysm80 Offline
cataclysm80  Offline
What applications would use the green wire?
Tav
Re: ELECTRONIC IGINTION wire diagram [Re: cataclysm80] #330170
05/29/09 10:17 AM
05/29/09 10:17 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Tav
Old 5 pin ECU and dual ballast resistor.
Re: ELECTRONIC IGINTION wire diagram [Re: GomangoCuda] #330171
05/29/09 11:38 AM
05/29/09 11:38 AM
cataclysm80 Offline
cataclysm80  Offline
When I first got my 70 challenger it had a mopar electronic distributor, dual ballast, and an aftermarket 5 prong ECU with all wires hooked up.
It wouldn't start, or even turn over.
I found an open in the neutral safety switch wiring, and when I fixed that it would turn over, but not start.
I replaced the ECU with a new aftermarket 5 prong unit from the local parts store, using the included wiring diagram to check that all the wires went where they were supposed to. (they did) Still the same situation, turned over, but no start.
I checked out some other things, and everything checked OK. Not knowing what else to do at the time, I called Year One tech support at about 10 PM. He told me to cut the green wire and tape it out of the way. I was hesitant, but that's what I did, and after that it worked fine. I still don't understand why though.
Tav
