Can I mix head studs and head bolts? #329563
05/26/09 05:22 PM
05/26/09 05:22 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
If you have seen the other posts, I blew the head gaskets in the 416 T/A with eddy heads. It is a restored car just with a nice 416 in it. Can I put studs to replace the bolts that are under the valve covers and use the bolts on the outside of the head to keep the restored look, or do I have to use all bolts or all studs?
Chris from New Jersey
Re: Can I mix head studs and head bolts? [Re: fig426] #329564
05/26/09 05:26 PM
05/26/09 05:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Why not?? tight is tight!
Re: Can I mix head studs and head bolts? [Re: Dodgem] #329565
05/26/09 06:05 PM
05/26/09 06:05 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I was always led to believe that studs gave a better clamping force than bolts if both were tightend to the same torque.
Re: Can I mix head studs and head bolts? [Re: Dodgem] #329566
05/26/09 06:26 PM
05/26/09 06:26 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I used bolts under the ex ports for header clearance issues with iron heads. I don't think a couple of studs in the middle will help against blowing gaskets
