Pushrod oiling (how much oil pressure should there be) #328486
05/25/09 07:07 PM
05/25/09 07:07 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
How much oil pressure should there be compared to shaft oiling...I just primed my engine with a drill and only showing 30lbs pressure.
I have crower cutaway lifters in an unbushed mega block that i was told would work with bushings or not.
Also have manton pushrods with 30 thousand hole that is suppose to keep the pressure up.
I know all of my shaft oilers would hit 75 psi almost instantly with the drill but that was using solid body comp lifters.
Re: Pushrod oiling (how much oil pressure should there be) [Re: sc301v] #328487
05/25/09 09:05 PM
05/25/09 09:05 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
thats a little low,I would use the P.R. with the restrictors in them!!
Re: Pushrod oiling (how much oil pressure should there be) [Re: sc301v] #328488
05/25/09 09:40 PM
05/25/09 09:40 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
1) What weight oil?
2) What are the Main and rod bearing clearances?
3) What are the side clearances on the rods?
4) Did you double check to make sure the P/R holes ARE .030?
5) What oil pump ? ( new or used, if used, are there any scratches in the end cover plate?
6) A good oil filter on there when priming right?
7) How big is the cam and did you check ( look down the galleys to make sure the oil band is staying in alignment during lift?
8) Is it a standard base circle cam?
RIP Monte Smith
Re: Pushrod oiling (how much oil pressure should there be) [Re: sc301v] #328489
05/25/09 10:48 PM
05/25/09 10:48 PM
Try rotating the motor over while priming and see if the oil pressure goes up and down If so you probally have a lifter problem exposing the oil galley at high lift Been there, done that
Re: Pushrod oiling (how much oil pressure should there be) [Re: Cab_Burge] #328490
05/25/09 11:46 PM
05/25/09 11:46 PM
San Jose Ca.
San Jose Ca.
possible fix!.020 bushing!
Re: Pushrod oiling (how much oil pressure should there be) [Re: boatracer572] #328491
05/26/09 05:20 PM
05/26/09 05:20 PM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
Boat racer, Is that roller lifter you're holding?
Re: Pushrod oiling (how much oil pressure should there be) [Re: CompWedgeEngines] #328492
05/26/09 07:15 PM
05/26/09 07:15 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
1) What weight oil?
All of the above and are all the galley plugs in ?
Re: Pushrod oiling (how much oil pressure should there be) [Re: BCFKody] #328493
05/26/09 10:14 PM
05/26/09 10:14 PM
San Jose Ca.
San Jose Ca.
yes,Its a comp #892!!
