Re: Pushrod oiling (how much oil pressure should there be)
[Re: sc301v]
#328488
05/25/09 09:40 PM
05/25/09 09:40 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
1) What weight oil? 2) What are the Main and rod bearing clearances? 3) What are the side clearances on the rods? 4) Did you double check to make sure the P/R holes ARE .030? 5) What oil pump ? ( new or used, if used, are there any scratches in the end cover plate? 6) A good oil filter on there when priming right? 7) How big is the cam and did you check ( look down the galleys to make sure the oil band is staying in alignment during lift? 8) Is it a standard base circle cam?
RIP Monte Smith
[Re: sc301v]
#328489
05/25/09 10:48 PM
05/25/09 10:48 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Try rotating the motor over while priming and see if the oil pressure goes up and down If so you probally have a lifter problem exposing the oil galley at high lift Been there, done that
[Re: Cab_Burge]
#328490
05/25/09 11:46 PM
05/25/09 11:46 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
possible fix!.020 bushing!
[Re: CompWedgeEngines]
#328492
05/26/09 07:15 PM
05/26/09 07:15 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
All of the above and are all the galley plugs in ?
