Hemi motor mount holes in block? #328362
05/25/09 04:30 PM
05/25/09 04:30 PM
MI
K
kjh440 Offline OP
kjh440  Offline OP
K
MI
I have my hemi that I am getting ready to put into my barracuda. It has been installed with a motor plate before but I want to use motor mounts. The pads are on the bolck but are not machined to accept the bolts.
Does anyone have the pattern layout and depth of these 3 bolt holes per side?
Re: Hemi motor mount holes in block? [Re: kjh440] #328363
05/25/09 08:17 PM
05/25/09 08:17 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Don't have a pattern, but I'd imagine if you got the mounts you could use as a template. They are drilled right thru and are for 7/16" bolts.
Re: Hemi motor mount holes in block? [Re: kjh440] #328364
05/26/09 09:24 AM
05/26/09 09:24 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
is that pad machined flat or left as cast ?
As said above they a drilled straight thru but you need to know exactly where .
