Re: rotor phasing experiment. whats this mean?
[Re: aarcuda]
#327702
05/25/09 12:01 AM
05/25/09 12:01 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If there is no vacuum to the advance mechanism, that plate is not going to move.
Pull the distributor cap off and twist the rotor clockwise and CCW. Not to the point of going into the advance springs but try to feel for slop in the oil pump to dist drive.
How is the timing chain?
[Re: RapidRobert]
#327704
05/25/09 10:23 AM
05/25/09 10:23 AM
Posts: 15,491 the boonies
aarcuda
the boonies
Pull the distributor cap off and twist the rotor clockwise and CCW. Not to the point of going into the advance springs but try to feel for slop in the oil pump to dist drive. How is the timing chain?
I think you nailed it that this is the "movement" that he is seeing at idle, that they both can(& do)make the rotor & therefore the timing marks jump around at idle. I used the collar on the dist shaft & a good chain & marks are rock steady now
I think that may be it. I did this last night when I first saw the rotor moving and ya, I can move the rotor back and forth quite a bit before getting into the mech advance. I do have a collar on it btw but my distr and oil pump drive are both used- probably got some slop (also two thinks I didn't replace when I built the motor last summer)
I'm going to try and video it. It's unreal
[Re: aarcuda]
#327705
05/25/09 10:26 AM
05/25/09 10:26 AM
Magnum
If that turns out to be the problem. Either a new HD oil pump drive or an ugly fix it to hammer the dist end and peen it wider.
[Re: Magnum]
#327706
05/25/09 01:02 PM
05/25/09 01:02 PM
Slop in the dist drive and chain should not affect rotor phase
[Re: aarcuda]
#327708
05/25/09 01:07 PM
05/25/09 01:07 PM
IF YOU ARE POINTING the light at your test hole, the movement you see should NOT be caused by the cam drive or intermediate shaft. It should all be in the relationship of the dist, possibly shaft wear, slop (looseness) in the advance plate, slop in the centrifugal mechanism, etc
What you are seeing in the test hole is the time difference between when the points open/ magnetic trigger and the spark happening at the rotor. You should be able to turn the dist. with an electric drill and get the same results.
[Re: AndyF]
#327710
05/25/09 02:08 PM
05/25/09 02:08 PM
aarcuda
the boonies
You think you see the rotor moving back and forth but that doesn't mean that it is actually moving. You are using a timing light as a strobe correct?
yes. the timing light fires on the wire coming from the cap terminal I windowed.
Im definitely seeing the rotor move first clockwise (to the left of the terminal) and then shoot over to the right wheni let off but it will center on the terminal at idle and after it settles at higher rpm.
I think my distributor is a pos that is just all wore out.
[Re: aarcuda]
#327711
05/25/09 02:46 PM
05/25/09 02:46 PM
RapidRobert
The rotor position(seen w the strobe light effect) is going to change constantly as the rpm changes(until you(at higher rpm's) hit the point where the curve is maxed out) & thats normal. I was thinking that the rotor was dancing at idle which would indicate tchain or intermediate shaft slot clearance or less likely dist shaft runout.
[Re: AndyF]
#327713
05/25/09 03:17 PM
05/25/09 03:17 PM
aarcuda
the boonies
Try a different timing light and see what happens.
i only have one. a snapon electronic and i trust it.
here a picture of the rotor with the reluctor lined up engine not running.
[Re: RapidRobert]
#327716
05/26/09 08:27 AM
05/26/09 08:27 AM
aarcuda
the boonies
no, its not dancing at idle (although every once and then it looks like the rotor os at the terminal right before the one Im looking at).
What I am seeing as I rev it up, the strobe is capturing the rotor move to the left of the terminal (reference picture above) for the reving part. If I rev it and hold it at a higher rpm, the rotor moves back to align with the terminal.
When I let go of the throttle and let it drop back to idle, the rotor moves way the heck to the right of the terminal as its decelerating and then re-aligns with the terminal again when its at idle.
Does this sound like what youve seen?
If the rotor and the relector and the puck-up and the cap are all stationary and the only thing i have going on is mechanical advance, the rotor position should ALWAYS be at the same location because I am firing off the spark plug wire and looking at the rotor. rotor being fixed to the reluctor means they always stay together irregardless of accel or decel or mech advance.
Maybe its just an inherent delay in my timing light that cant pick up the changes in the strobe as fast as its changing when i rev it. ya, maybe the timing light is not changing the strobe as fast as the spark is changing so it shows a delay
