Trans temp guage - this CAN'T be right !? #327594
05/24/09 08:47 PM
05/24/09 08:47 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Installed a trans temp guage in the Satellite today. At the advice of my trans guy, I plumbed the sending unit into the out line, instead of the pan. Went for a quick drive and about freaked out! Temp guage went to 150 as soon as I started the car (cold), and went to over 250 on a 5 minute drive! . Back in the garage, I checked the fluid at the dipstick; it was barely even warm. felt the cooler lines, they were nice and cool. The guage can't be right (??).What gives?
It's an auto-meter electric guage. wired from sender to (S) side of guage: (I) side of guage to 12v source at fuse-box. pretty straight forward. What could be wrong here?
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327595
05/24/09 09:25 PM
05/24/09 09:25 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Mismatched sender/gauge or defective parts. Can`t be anything else.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Trans temp guage - this CAN'T be right !? [Re: gamagoat6x6] #327596
05/24/09 10:25 PM
05/24/09 10:25 PM
Your hookup sounds correct, when you take it off you might stick it in the coolant & see how it acts.
Re: Trans temp guage - this CAN'T be right !? [Re: RapidRobert] #327597
05/25/09 12:11 AM
05/25/09 12:11 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'd boil some water and test the sender/gauge just like a thermostat...grab the better half's kitchen thermometer and a good pan and fire up the stove. Make sure she will be gone long enough that you won't get busted! I don't know a female that would find the humor in a car battery sitting on the kitchen counter with a temp gauge hooked to it.
Re: Trans temp guage - this CAN'T be right !? [Re: Jeremiah] #327598
05/25/09 12:32 AM
05/25/09 12:32 AM
Puyallup, WA
Puyallup, WA
I'll pull the sending unit (arghh), and stick it in a pan of hot water with a thermometer in the water. I'm sure I'll find that the guage / sending unit is about 120* off.
Next qustion: at this point, Is it safe to assume its the sending unit?, or could the guage be the problem?
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327599
05/25/09 12:40 AM
05/25/09 12:40 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Autometer hookup uses three wires, ignition (12v) Sender & Grd... you only list 12v & sender... When viewed from the back of the gauge 12v goes to the left upper post, sender goes to right upper post & ground goes to the center lower post...
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327600
05/25/09 12:41 AM
05/25/09 12:41 AM
Are you absolutely sure the sender is grounded?
Some of these gauges are a "bridge" circuit and that means there's a terminal on the CASE of the gauge which must be grounded.
Re: Trans temp guage - this CAN'T be right !? [Re: 1_WILD_RT] #327601
05/25/09 12:49 AM
05/25/09 12:49 AM
Puyallup, WA
Puyallup, WA
You're smart; and I'm stupid! Looking at the diagram, there is a ground, and I did not hook it up. Could this cause it to miss-read, however??
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327602
05/25/09 01:20 AM
05/25/09 01:20 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You're smart; Sometimes and I'm stupid! No, just in to much of a hurry BTDT now I read the book Looking at the diagram, there is a ground, and I did not hook it up. Could this cause it to miss-read, however?? Absolutely....
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327603
05/25/09 01:22 AM
05/25/09 01:22 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
yup,,, ad the ground........
I am truckless..
Re: Trans temp guage - this CAN'T be right !? [Re: 340SHORTY] #327604
05/25/09 01:50 AM
05/25/09 01:50 AM
Puyallup, WA
Puyallup, WA
Thanks Randy!! added the ground, problem solved. reads right where it should. Crazy thing is, I read this diagram, and never saw the ground. Sometimes I guess you see what you want to see (??)
Thanks again, guys!
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327605
05/25/09 02:10 AM
05/25/09 02:10 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Awesome...I'll save this one to the mental archives. Learn something every day! Here's to the power of Moparts
Re: Trans temp guage - this CAN'T be right !? [Re: Jeremiah] #327606
05/25/09 02:28 AM
05/25/09 02:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Glad it worked!!
Re: Trans temp guage - this CAN'T be right !? [Re: StealthWedge67] #327607
05/25/09 07:40 AM
05/25/09 07:40 AM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
Don't worry, we all do it, sooner or later. Strange that there's no word for it (that I know of).
