Vinyl top installed #327362
05/24/09 06:25 PM
05/24/09 06:25 PM
fullfloater Offline OP
Just finished a couple of hours ago putting vinyl top on 69 RR ,Put out in sun and it started bubbling up ,it was so hot i couldn,t touch it ,pushed back in shop and worked out bubbles ,they seem to be slowing mostly ,but a few seem to try and come back ,getting concerned ,i followed diections in tech forum ,roof had new paint job on it ,several months old ,used 3M super adhesive trim ,did i do something wrong ,cleaned surface with thinner before installing ,any Ideas ?
Re: Vinyl top installed [Re: fullfloater] #327363
05/24/09 09:05 PM
05/24/09 09:05 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
I'll be watching for the replies since mine has the same problem with the same good prep.
Until total honesty is on the table, we're not even talking about reality...
Re: Vinyl top installed [Re: Iceman01] #327364
05/24/09 09:32 PM
05/24/09 09:32 PM
I kept working it down all afternoon and it looks like it finally stuck ,i assuming it was trying to breath from chemical still being too wet when applied it in some places ,thats all i can figure ,it was real humid today when i put it on ,it had me concerned ,hope it works
Re: Vinyl top installed [Re: fullfloater] #327365
05/24/09 10:06 PM
05/24/09 10:06 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I thought you were suppose to put the vinyl out in the sun to soften it up and make it easier to work with, then install it in the shade.
Did someone recommend putting the finished car out in the sun?
Re: Vinyl top installed [Re: fullfloater] #327366
05/24/09 10:17 PM
05/24/09 10:17 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
You are exactly right. You should spray both sides and wait at least a full two minutes before placing the vinyl down. It should look dry but it's a fine line. Wait too long and it will come loose later.
Bob
Re: Vinyl top installed [Re: Kingy] #327367
05/25/09 07:36 AM
05/25/09 07:36 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
You sould also scuff the paint with a red scotch brite before putting on the glue.
Re: Vinyl top installed [Re: AdamR] #327368
05/25/09 09:50 AM
05/25/09 09:50 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Wiping with thinner is not a good idea because it leaves a film like residue.
I scuffed mine with red scotch brite and wiped with a 50/50 mix of Isopropyl alcohol and water and let dry 30 minutes.
As stated earlier the contact cement must be applied to both sides and allowed to dry for 10 minutes before pressing together.
