Tunnel ram / carb position question #327244
05/24/09 05:41 PM
05/24/09 05:41 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Picture this. Tunnel ram intake with a single Dominator carb. The questions are:
Is there any known advantage to having the carb mounted straight ahead, on a slight angle, or sideways?
Is there any known advantage to having the carb mounted centered front to back, slightly towards the front, or slightly to the rear?
I realize there are many variables. General answers are what I am looking for.
Thanks.
TR Waters
Re: Tunnel ram / carb position question [Re: TrWaters] #327245
05/25/09 02:35 AM
05/25/09 02:35 AM
I would replace that top with a dual top so the carbs align over the ports like there suppose to
Re: Tunnel ram / carb position question [Re: Cab_Burge] #327246
05/25/09 09:53 AM
05/25/09 09:53 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
ive got a few tunnel rams..
singles and daul carb..
first impression..the single carb...just looks wrong..
the spread between the rear 4 and the front 4 just looks too far apart for a single carb to work efficiently...
but its just an observation...?
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Tunnel ram / carb position question [Re: cheapstreetdustr] #327247
05/25/09 01:28 PM
05/25/09 01:28 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Two replies, neither of which have anything to do with the question that was asked. Thanks anyway.
TR Waters
Post deleted by Defbob [Re: TrWaters] #327248
05/25/09 03:18 PM
05/25/09 03:18 PM
Re: Tunnel ram / carb position question [Re: TrWaters] #327249
05/25/09 04:51 PM
05/25/09 04:51 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i'm still not sure if this has anything to do with the question , but you can't put one carb anywhere, or turn it anyway to make it work efficiently on a t/r. i've been running t-rams for 25-30yrs. they were meant for 2 carbs.
Re: Tunnel ram / carb position question [Re: tjmarcus1] #327250
05/25/09 05:12 PM
05/25/09 05:12 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
I know this isn't the answer you want but every dyno sheet I've seen with a single 4 on a tunnel ram gave up a ton of power compared to a 2x4 setup. Dave
Re: Tunnel ram / carb position question #327251
05/25/09 07:54 PM
05/25/09 07:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
twist to place carbs more inline with the ports
Yup - the port offset is 1 rod width or about 1", and the closer the top is to the ports vertically, and the smaller the plenum volume is, the more important it should be.
I wouldn't be surprised if some had anti-reversion stubs underneath that flared out asymmetrically to help this...
I have a feeling that high G cars may need the carb bumped forward a tiny bit to allow for the accel moving the fuel toward the back ports.
Boffin Emeritus
Re: Tunnel ram / carb position question [Re: polyspheric] #327252
05/26/09 09:32 PM
05/26/09 09:32 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
I dont dispute the fact that 2 may work better than one. I was just interested in the placement if one carb was used.
This particular top is a Hogan's , and it does have diversion underneath.
Thanks.
TR Waters
