HARD starting 440???? #327223
05/24/09 05:10 PM
05/24/09 05:10 PM
abc440 Offline OP
abc440  Offline OP
I have a 440 with a 750 edlebrock (electric choke).I have trouble starting the motor after it sets 2 or 3 days. Lasts summer it would start after 15-20 seconds turning over, but seems to be worse this time. No changes. I am afraid i am going to burn the starter up. Any ideas? THANKS DAVID
Re: HARD starting 440???? [Re: abc440] #327224
05/24/09 05:13 PM
05/24/09 05:13 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you looked down the carb while working the throttle to see if the accelerator pump is working? Is the choke adjusted right? What diagnosing have you done?
Re: HARD starting 440???? [Re: abc440] #327225
05/24/09 05:14 PM
05/24/09 05:14 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i would say you are getting too much fuel in some way like after you shut it off.[too much psi]
Re: HARD starting 440???? [Re: abc440] #327226
05/24/09 05:19 PM
05/24/09 05:19 PM
places
79powerwagon Offline
places
Tune it up properly.
Re: HARD starting 440???? [Re: abc440] #327227
05/24/09 06:13 PM
05/24/09 06:13 PM
California
6superbee9 Offline
6superbee9  Offline
California
I'd say double check your choke and fuel pressure and filter. I had the same issue a while back and my fuel pump was the problem.
Re: HARD starting 440???? [Re: 6superbee9] #327228
05/24/09 06:27 PM
05/24/09 06:27 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
After it sits for a few days pop off the air cleaner lid, and look down the carb while 'pumping' the throttle by hand. If you see no fuel squirting out of the accelerator pump nozzles your carb is either leaking fuel out of the bowls, or more likely the fuel is evaporating out of the bowls after sitting a few days. Each time you pump it by hand while watching you should see a healthy shot of fuel shooting out of the those nozzles.
If there is a lot of fuel shooting out on each pump your problem could be either a weak spark or an incorrectly adjusted choke.
Re: HARD starting 440???? [Re: DaytonaTurbo] #327229
05/25/09 12:18 AM
05/25/09 12:18 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It's the fuel evaporating in the fuel bowls.
Now you have no accelerator pump shot and now it won't easily start.
For some reason, some engines do not need pump shot to start, these engines don't mind having and Edelbrock on them.
Why does it take so much cranking before you have pump shot? First the passenger side fuel bowl needs to be full. Once it's full fuel will then flow over to the driver's side fuel bowl. Once it's full it's high enough to feed the acc pump cylinder. Then without a constant supply it will only give you a couple of pump shots, hopefully it's enough to fire up your cold engine.
Guess why Holley's do NOT have this problem?
Even with 80% of their fuel bowl contents evaporated. Since it's acc pump feeds from the bottom, it'll squirt as much as you desire and that cold, not started in 2 months engine will instantly spark to life.
Re: HARD starting 440???? [Re: Magnum] #327230
05/25/09 01:42 AM
05/25/09 01:42 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
THe Eddy carbs have that problem.
I would bet you have an iron intake. Mine did that but it has been better with an aluminum one. I'm not sure why that seems to matter as the problem should be there the next day and not wait a few but ????????
Could also have to do with having a fuel line with a slight "P trap" near the carb that my other ones that had more trouble didn't have. Maybe fab up a line that has something like that going on.
Maybe you could get one of those dual feed lines for the carb and drill the driver side out for it to work. That would speed up the process listed above.
Re: HARD starting 440???? [Re: abc440] #327231
05/25/09 05:56 PM
05/25/09 05:56 PM
abc440 Offline OP
abc440  Offline OP
Thanks gentlemen for all the responces. I changed out the coil, checked the choke, no difference in hard starting. I have the glass see through filter, looked ok. But stopped at Auto Zone and bought new filters and changed it. Started faster. I guess you cant tell by just looking. Overlooked a simple fix. THANKS AGAIN!!!!
Re: HARD starting 440???? [Re: abc440] #327232
05/26/09 09:10 AM
05/26/09 09:10 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Why these frikken thing aren't banned from the market is beyond me! They are crap. Pretty untilthey leak and burn your car to the ground. Not legal at most tracks.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: HARD starting 440???? [Re: abc440] #327233
05/26/09 09:19 AM
05/26/09 09:19 AM
k.i.s.s. always! Glad ya got it
Re: HARD starting 440???? [Re: RapidRobert] #327234
05/26/09 06:42 PM
05/26/09 06:42 PM
IA
landon1 Offline
landon1  Offline
IA
i've had a glass filter for 6 years now...no problems, but i'll probably start using the plastic canisters since just the element on a glass filter is $4, while you can get plastic for 1/2 the price
the clear glass filters do go fast in my experience also, they may look good, but can not be allowing enough fuel to the carb
'71 Satellite Sebring 440
