Brake self adjusters #327060
05/24/09 01:25 PM
05/24/09 01:25 PM
Anonymous OP
Anonymous OP
I removed the front brake drums on my 68 Charger R/T to inspect the brake components and found the previous owner had done away with all self adjusting hardware when he did a brake job in 1994. My question is should I buy and reinstall new self adjusters or not? Do the self adjusters work well?
Re: Brake self adjusters #327061
05/24/09 01:53 PM
05/24/09 01:53 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I believe you did not have self adjusters in the front from the factory.. My 67 coronet with the 11" brakes did not..
Re: Brake self adjusters [Re: minivan] #327062
05/24/09 02:22 PM
05/24/09 02:22 PM
scratchnfotraction Offline
I do the same to all my drum brakes
I tend to keep the service up on mine tinkering with it
I spoon the brakes up when the pedle travils a little but not 1/2 way,I keep em tight and the pedle solid
about every 3 mounths or so I spoon them,they could go longer in between the spooning
not saying it the right way but I do stay on top of the brakes on mine
results may vary
Re: Brake self adjusters [Re: scratchnfotraction] #327063
05/24/09 02:38 PM
05/24/09 02:38 PM
MNobody Offline
MNobody  Offline
I alway's adjust mine so they drag just a little bit, pedal travel is a good indication when they need adjusting, as mentioned.
Re: Brake self adjusters [Re: scratchnfotraction] #327064
05/24/09 02:44 PM
05/24/09 02:44 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
If I have drums I prefer to adjust them manually. I feel it gives better brake balance when the shoes get a little worn. This is especially true if the drums are not the same diameter left to right due to truing on a brake lathe.
Re: Brake self adjusters #327065
05/24/09 05:26 PM
05/24/09 05:26 PM
Andrewh Offline
Andrewh  Offline
look at the star wheel. Are there a lot of little teeth, or are the teeth fairly large.
If they are little teeth, then you are correct, the previous owner got rid of the self adjustment hardware. If they are big teeth, then it did not come with them.
