Re: MSD mechanical advance distributor
[Re: Quicktree]
#326080
05/23/09 11:30 PM
05/23/09 11:30 PM
you may want to add a 50cc pump to the front and come down on squirter size.use brown cams.
i don't believe a 50cc pump is necessary. replace the pump cam to the blue one and reduce the squirter to a 35. that should solve the problem. the reason your getting that hesitation is the stock cams are not aggressive enough at the hit. with the blue cam you might be able to get away with as little as a 31 squirter.
