Front Bench seat removal #325690
05/22/09 01:11 PM
05/22/09 01:11 PM
Long Island, New York
Tony H Offline OP
Tony H  Offline OP
1970 Valiant
That sucker is low, I cannot see under to figure out what to disassemble. What's the best way to get the front seat out of the car. Is there hardware that will separate the upper frame from the slide adjuster part?
'75 CJ5 with all glass body and a 350 Chevy SB
'85 Chevy Stepside (the wife's)
'89 Volvo
All 100% maintained by me.
'70 valiant DD for my son
'74 Dart Swinger..Latest endeavor
http://home.lyse.net/brox/TonyPage4.html
Re: Front Bench seat removal [Re: Tony H] #325691
05/22/09 01:14 PM
05/22/09 01:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There should be 4 nuts under the car 2 on each side. Stuff the seat belts back through the seat and pull it out the door.
Re: Front Bench seat removal [Re: stumpy] #325692
05/22/09 02:08 PM
05/22/09 02:08 PM
Tony H Offline OP
Tony H  Offline OP
I knew I could do it from the bottom, I was just thinking that maybe there was additional hardware inside that would separate th eupper track from the lower
'89 Volvo
Re: Front Bench seat removal [Re: Tony H] #325693
05/22/09 03:45 PM
05/22/09 03:45 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Indeed, the tracks and the seats started life as separate entities before they were assembled. Technically, the same can be said for ALL of the pieces under your seat (lower/upper seat track halves, etc.). Some of those components can still be separated with ease, others have been tacked or otherwise made more challenging to separate as part of the manufacturing process.
You have already been advised as to the recommended and by far easiest method of removing the front seat from your car. Once you follow that path, knock yourself out with taking other stuff apart. Ignoring that advice is only going to make your job needlessly difficult.
Down to just a blue car now.
