Valve Spring? #323438
05/20/09 09:54 AM
05/20/09 09:54 AM
Anonymous OP
Anonymous OP
I am considering using mopar performance valve springs #P3690993 on a set of 516 heads for a 440 rebuild. Can I use the stock retainers on this spring? If not, what should I use?
Mike
Re: Valve Spring? #323439
05/20/09 09:56 AM
05/20/09 09:56 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do the stock retainers hit tightly into the springs? If not , NO I wouldn't use them .
Re: Valve Spring? #323440
05/20/09 10:49 AM
05/20/09 10:49 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Mike
Do you mean #P3690933 valve springs? If you do then I don't see a problem as I have them on 3 of my engines with stock retainers.
Don't forget to check and adjust installed spring height when assembling the heads
Re: Valve Spring? [Re: pacifica] #323441
05/20/09 10:50 AM
05/20/09 10:50 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Mike
