Re: big silly '14 JKU M-380 - "Oxx"
[Re: poorboy]
#3228249
04/20/24 11:27 AM
04/20/24 11:27 AM
Posts: 3,113 N.W. Florida
Fat_Mike
N.W. Florida
Man, I like to watch you as you are working through the details of this project. Its not something that I personally would do, we don't have places around here where we can off road very much, but I have not missed one of your posts yet. Your work is great, and has many details most build threads don't get into. I urge you to continue the process, there are many that are watching but are not commenting. What you are doing is well past anything I have experience doing, so other then a short suggestion or question, there isn't much I can do to assist in your progress past the point of watching. The best I can do is be a sideline cheerleader. Keep at it, your doing great! Love your posts! I'm learning as I follow along. Gene Another cool build thread by Mad Max.
[Re: moparx]
#3228600
04/22/24 02:01 PM
04/22/24 02:01 PM
Posts: 250 Falcon, CO
Mad-Max
Falcon, CO
ok - just didn't need to clog up the forum if not really required - thanks for the responses So in the spirit of making things easier to maintain, over the weekend I made three strategically-placed holes in the floor to give me full access to the gas tank, including removing the sending unit to replace the fuel pump - all without having to drop the tank (and cover, and armor, and and and), and I'll make three matching bolt-on trap door panels to cover things up - First - sending unit. There's two braces that meet up under the floor, and I cut away as much panel as I could without cutting into the braces, just to have something to start with, and lucked out because I can juuuust squeeze out the sending unit as-is :thumbsup: - and I highly recommend the sending unit ring clamp tool - like $30 on Amazon and WELL worth the $ - Next - the OE fuel level system uses whateverthehell ohms range (still don't know for certain), so I'm using a stand-alone 8" float assembly from ISSPRO that matches my gauges, with the respective 240-33 ohms rating; drilled the hole, and I can reach inside the tank and I'll use a nice ring clamp to secure the 5 bolts from the bottom - here's a look inside the tank - there's about...I dunno...1/4" between the bottom of the float and the bottom of the tank...so I'll have a bit 'more' after the gauge reads empty other side - Next - return line. My Holley Sniper EFI needs a return line, and I got this nice return line kit from EFI Systems Pro - same place I got the Sniper from - great place and great tech support - Float and return line installed - little heat and the OE plastic return line tubing slid right over the new fitting, and used an EFI clamp to make sure it stay's put - Next - the main vent. Wanted to be able to access the main vent and fuel full/vent tubes, so out came the deathwheel and another hole in the floor is made -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
[Re: Mad-Max]
#3231597
05/07/24 05:29 PM
05/07/24 05:29 PM
Mad-Max
Falcon, CO
throttle, brake, and e-brake pedals, hydrobooster/m-cylinder, and inner fender liner all fitted in place. Brake and fuel lines can now be installed. Also have a mind's eye of my dash. Progress (y) This big hole had to be filled in - it's a cowl vent that I don't want, so I covered it with 3/16 plate which also serves as the brake pedal mount - works great. The Jeep had a throttle 'sensor' pedal so I'm using the Dakota's throttle pedal, and e-brake mechanism, but using the Jeep's brake pedal, all three of which were altered for better placement - and with the brake pedal located, so then can be the hydrobooster and m-cylinder, and brake lines to the frame - trimmed the inner liner to clear the brakes - fits great - and one of my favorite parts, the dash - this is a basic minds' eye of how it's gonna look -
Re: big silly '14 JKU M-380 "Kilroy"
[Re: Mad-Max]
#3232518
05/13/24 11:57 AM
05/13/24 11:57 AM
Mad-Max
Falcon, CO
Re: Help ID Radiator
[Re: RalleyA12]
#3234701
05/24/24 12:26 PM
05/24/24 12:26 PM
Mad-Max
Falcon, CO
in a M38 or M35 deuce...and this is what I came up with - this is what an actual M35 and M38 dash looks like - M35 M38 This is the actual dash 'frame', which will bolt to the interior - add a set of simple 2" heater vents - I'm finishing up some of the details and should have it bolted in place soon. After that...I crack open the box with the Painless wiring harness and then things'll really get sporty
[Re: poorboy]
#3234750
05/24/24 04:51 PM
05/24/24 04:51 PM
Mad-Max
Falcon, CO
yep considered the column, and no there won't be any physical or visual interference issues...at least none that'll be any issue. I'll still be cutting a channel into the bottom of the panel(s) for the column (the two lower/inner gauges (oil press and oil temp) are 2" apart to accommodate the 1.5" column - this is just the initial glean on how it is going to all fit together.
[Re: Mad-Max]
#3235649
05/30/24 12:59 PM
05/30/24 12:59 PM
Mad-Max
Falcon, CO
