Re: big silly '14 JKU M-380 - "Oxx" [Re: poorboy] #3228212
04/20/24 07:32 AM
04/20/24 07:32 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
iagree
Most of what you are doing is way beyond my knowledge and skill level, but it is still worth watching. Maybe I'll learn something.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: big silly '14 JKU M-380 - "Oxx" [Re: poorboy] #3228249
04/20/24 11:27 AM
04/20/24 11:27 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Originally Posted by poorboy
Man, I like to watch you as you are working through the details of this project. Its not something that I personally would do, we don't have places around here where we can off road very much, but I have not missed one of your posts yet.
Your work is great, and has many details most build threads don't get into. I urge you to continue the process, there are many that are watching but are not commenting. What you are doing is well past anything I have experience doing, so other then a short suggestion or question, there isn't much I can do to assist in your progress past the point of watching. The best I can do is be a sideline cheerleader.
Keep at it, your doing great! Love your posts! up biggrin I'm learning as I follow along. Gene
iagree
Another cool build thread by Mad Max.
Re: big silly '14 JKU M-380 - "Oxx" [Re: Fat_Mike] #3228270
04/20/24 01:18 PM
04/20/24 01:18 PM
moparx Offline
moparx  Offline
i too, enjoy this build progress.
as with most things being modified, i like to watch, because i never know what kind of method i might be able to "steal" for use in the future. up
please keep this going.
beer
Re: big silly '14 JKU M-380 - "Oxx" [Re: moparx] #3228600
04/22/24 02:01 PM
04/22/24 02:01 PM
Falcon, CO
Mad-Max Offline OP
Mad-Max  Offline OP
Falcon, CO
ok - just didn't need to clog up the forum if not really required - thanks for the responses thumbs
So in the spirit of making things easier to maintain, over the weekend I made three strategically-placed holes in the floor to give me full access to the gas tank, including removing the sending unit to replace the fuel pump - all without having to drop the tank (and cover, and armor, and and and), and I'll make three matching bolt-on trap door panels to cover things up -
First - sending unit. There's two braces that meet up under the floor, and I cut away as much panel as I could without cutting into the braces, just to have something to start with, and lucked out because I can juuuust squeeze out the sending unit as-is :thumbsup: - and I highly recommend the sending unit ring clamp tool - like $30 on Amazon and WELL worth the $ -
Next - the OE fuel level system uses whateverthehell ohms range (still don't know for certain), so I'm using a stand-alone 8" float assembly from ISSPRO that matches my gauges, with the respective 240-33 ohms rating; drilled the hole, and I can reach inside the tank and I'll use a nice ring clamp to secure the 5 bolts from the bottom -
here's a look inside the tank - there's about...I dunno...1/4" between the bottom of the float and the bottom of the tank...so I'll have a bit 'more' after the gauge reads empty smile
other side -
Next - return line. My Holley Sniper EFI needs a return line, and I got this nice return line kit from EFI Systems Pro - same place I got the Sniper from - great place and great tech support -
Float and return line installed - little heat and the OE plastic return line tubing slid right over the new fitting, and used an EFI clamp to make sure it stay's put -
Next - the main vent. Wanted to be able to access the main vent and fuel full/vent tubes, so out came the deathwheel and another hole in the floor is made -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler'
52 Willys M-38 "Poncho"
