440 (S 440) ??? #3231359
05/06/24 12:06 PM
05/06/24 12:06 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
68 casting 440 with S 440 in ID pad, vin pad is blank, cast date 9-27-68. Why the S 440 on ID pad?
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231362
05/06/24 12:09 PM
05/06/24 12:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
And what appears to be an upside-down S at that.
I'm gonna guess Service block, as in dealership parts dept, maybe a warranty replacement if not over-the-counter.
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231366
05/06/24 12:14 PM
05/06/24 12:14 PM
Cab_Burge Online work
Cab_Burge  Online Work
Looks like a later HP crank assembly with the external balancer or maybe an early (1969) six pack motor confused shruggy
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231381
05/06/24 12:32 PM
05/06/24 12:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That late '69 casting date would be for the '70-later model years and that external balanced damper is '70-'71 HP only. '69 didn't have the heavy rods.
Re: 440 (S 440) ??? [Re: Cab_Burge] #3231387
05/06/24 12:55 PM
05/06/24 12:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
69 6pk motors were not external balance , that started for the 70 model year.
Re: 440 (S 440) ??? [Re: John_Kunkel] #3231388
05/06/24 12:55 PM
05/06/24 12:55 PM
That's a 68 casting date
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231390
05/06/24 12:58 PM
05/06/24 12:58 PM
JohnRR Offline
JohnRR  Offline
That looks like a 9 not an 8. S is a service replacement as stated , either over the counter or warranty , a warranty replacement SHOULD have been stamped by the mechanic installing it . Service replacements should have a tag that was affixed by a rivet giving a code as to what spec the engine was built to.
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231391
05/06/24 12:59 PM
05/06/24 12:59 PM
JohnRR Offline
JohnRR  Offline
What else is on the I D pad ? Looks like a W , a V or an A , is there a T ... assembled on 1/21 , considering the balancer it would be 70 be at least 1970 .
Re: 440 (S 440) ??? [Re: JohnRR] #3231392
05/06/24 01:01 PM
05/06/24 01:01 PM
Look at the 9 for the month and compare it to the 68, you can then see that it's an 8, looks like a V on upper right corner.
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231395
05/06/24 01:10 PM
05/06/24 01:10 PM
JohnRR Offline
JohnRR  Offline
I see it now , you are correct.
That aside Chrysler had horrible inventory control, that was either lost in the shuffle or it had an issue that caused it to be cast aside and fixed at at a later date, when the block was cast doesn't matter.
Do you have the engine in your possession ?
Re: 440 (S 440) ??? [Re: JohnRR] #3231400
05/06/24 01:41 PM
05/06/24 01:41 PM
Yes I do, here's a better pic of the 68. The V ended up being an upside down A. Pistons are flat tops with 4 valve reliefs.
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231440
05/06/24 05:46 PM
05/06/24 05:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think I see an F on the top pad, as in Model Year 1970, yet what looks like an assembly date of Jan 21, 1972.
If that date is genuine: with a casting date that much earlier, maybe the block was at the bottom of the pile or in the back of the room, and that's why it took so long ?
And if that's the original paint, was Chrysler still painting blocks or service replacements orange ?
Re: 440 (S 440) ??? [Re: topside] #3231477
05/06/24 08:49 PM
05/06/24 08:49 PM
The 2 is for 2nd shift, not 1972.
Re: 440 (S 440) ??? [Re: GODSCOUNTRY340] #3231522
05/07/24 06:04 AM
05/07/24 06:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Looks like you have a service replacement long block to me. What is the date casting on the heads if they are original? It’s a 70-71 replacement but I wonder why it’s not stamped HP? If it has 4 valve reliefs in the pistons, that’s a six pack motor. I can’t remember if the 4 barrels got the 4 valve reliefs are not. It been too long since I saw a stock one. Good score, though.
Re: 440 (S 440) ??? [Re: fastmark] #3231667
05/08/24 12:59 AM
05/08/24 12:59 AM
Mopar did not install any stock cast 4 valve relief pistons that I have heard of or seen in any of their over the counter or factory installed in standard vehicles, just the 1969 six pack motors shruggy
Re: 440 (S 440) ??? [Re: Cab_Burge] #3231683
05/08/24 08:27 AM
05/08/24 08:27 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Here’s the piston from my 65,000 miles 6 pack Superbird. I bought it in 82 and was the first to take it apart. We sent this off to Race Tech to make me a set of .010 replacements years ago. It has four valve reliefs. The one 69 6 pack A12 Bee I bought in 85 just had flat top cast pistons. It’s my understanding that the 69 6 pack got the same pistons and rods that the other 440 motors got. Nothing special in 69.
My Butterscotch A12 had the pistons replaced when I bought it in 81 with 11.5 domed pistons. All three of the 70 440 HP 4 barrel cars or motors I bought had the pistons gone or replaced when I bought them so I can’t testify to those 4 barrel applications. I just bought and sold 70 440 6 pack motor that had stock 4 valve pistons but I did not take pictures. It had been worked on though and was a stock bore/pistons with a Hemi crank and neutral balance job. .001 wear in the cly. It had a 70 iron six pack and 70 carbs but I did not get that in the deal.
Re: 440 (S 440) ??? [Re: fastmark] #3231684
05/08/24 08:31 AM
05/08/24 08:31 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It’s been a long time since I looked at an NHRA tech bulletin but I think the compression height on a 70 6 pack is higher than 4 barrel. They may not have needed valve reliefs
Re: 440 (S 440) ??? [Re: fastmark] #3231688
05/08/24 09:07 AM
05/08/24 09:07 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
nhraracer.com shows the 440 six pack has a deck clearance of .001 and has valve notches. 440 four barrel shows .051 deck clearance, and flat tops.
Re: 440 (S 440) ??? [Re: John Brown] #3231742
05/08/24 01:07 PM
05/08/24 01:07 PM
NHRA only has what tech information Mopar provided them devil whistling work shruggy
IE, T/A fiberglass hoods on 1971 Hemi Challengers per the letter typed up at the 1974 Wnternationals for Dick Landy to run his 1971 Hemi Challenger in SS/D saying they supposedly ran out of Shaker hoods for a "short time" in the early production of the 1971 Challengers and had some left over T/A hoods and installed them on to expedite shipping them whistling shruggy
Re: 440 (S 440) ??? [Re: Cab_Burge] #3231765
05/08/24 02:48 PM
05/08/24 02:48 PM
JohnRR Offline
JohnRR  Offline
You might have gotten something different in 69 as a racer because the 69 440 6pk shortblock was basically the same as the 375HP 4 bbl engine , other than it being a special care build , shot peened rods , hi taper cam .
The 70 6pk got a higher compression ratio with a taller piston than the 69 .
