440+6 Carter Fuel Pump #3231455
05/06/24 07:25 PM
05/06/24 07:25 PM
Pennsylvania
70Xman Offline OP
70Xman  Offline OP
Pennsylvania
I ordered a Carter fuel pump, M4845, from Rock Auto that was supposed to be for a V code 440 and the threaded output fitting to the vapor separator is so tiny that the factory hard line isn't even close to fitting. It has a 3/8 inlet nipple, but the outlet side is way small. A Carter M3672 fuel pump has the correct outlet thread, but the inlet is 5/16. What pump is everyone using that has the correct inlet and outlet, on their HP 440's?
Re: 440+6 Carter Fuel Pump [Re: 70Xman] #3231470
05/06/24 08:23 PM
05/06/24 08:23 PM
CrazyD Offline
CrazyD  Offline
Re: 440+6 Carter Fuel Pump [Re: CrazyD] #3231478
05/06/24 08:53 PM
05/06/24 08:53 PM
Pennsylvania
70Xman Offline OP
70Xman  Offline OP
Pennsylvania
Thanks!
Re: 440+6 Carter Fuel Pump [Re: 70Xman] #3231507
05/06/24 11:34 PM
05/06/24 11:34 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
carter 6903
