Carter M4845 Fuel Pump Outlet Issue.....
#2035961
03/21/16 08:25 PM
03/21/16 08:25 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Went to install my Six Pack Lines onto my Carter M4845 fuel pump and the fitting it too large? Read all the posts on this pump as the one to get, but what gives? Do I need an adapter or ? Any help would be appreciated.
I think the fitting is 1/2, but the female end on the pump looks like 5/16 ?
Admiration For Multiple Carburetor Vehicles...
Re: Carter M4845 Fuel Pump Outlet Issue.....
[Re: Stewpar]
#2036180
03/22/16 01:16 AM
03/22/16 01:16 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I think the fitting is 1/2, but the female end on the pump looks like 5/16 ? The Carter M4845 pump uses an 1/8 NPT threaded outlet, the fitting you require is a 1/8" NPT X 1/2-20 inverted flare for 5/16" hard line adapter, most parts stores with a knowledgeable employee can easily find this under brass brake and fuel adapters, if they carry the Gardner Westcott line, the PN# is 481c5x2 or you could purchase from www.quadrajetparts.com PN#2218J for $9, or try Member Scott Smith/Harms Automotive Mike On another note I generally find the Carter M4845 too high in pressure for the Holley needle seats, the pump's output is 6-8 psi, and the GPH is poor at 33 GPH, I've found that using the Carter HEMI pump M6903 better suited for the sixpack supplying 120 GPH, but at 5-6.5 psi, I find the 6bbl induction prefers volume over pressure...just a note for future reference
[Re: DAYCLONA]
#2036709
03/22/16 08:12 PM
03/22/16 08:12 PM
Stewpar
Wisconsin
I think the fitting is 1/2, but the female end on the pump looks like 5/16 ? The Carter M4845 pump uses an 1/8 NPT threaded outlet, the fitting you require is a 1/8" NPT X 1/2-20 inverted flare for 5/16" hard line adapter, most parts stores with a knowledgeable employee can easily find this under brass brake and fuel adapters, if they carry the Gardner Westcott line, the PN# is 481c5x2 or you could purchase from www.quadrajetparts.com PN#2218J for $9, or try Member Scott Smith/Harms Automotive Mike On another note I generally find the Carter M4845 too high in pressure for the Holley needle seats, the pump's output is 6-8 psi, and the GPH is poor at 33 GPH, I've found that using the Carter HEMI pump M6903 better suited for the sixpack supplying 120 GPH, but at 5-6.5 psi, I find the 6bbl induction prefers volume over pressure...just a note for future reference $1.98 at Advanced Auto Parts! Life is so easy when you know EXACTLY what you need. I see some pictures with Teflon tape on the threads, is this necessary? Thanks Mike!
[Re: Stewpar]
#2036842
03/22/16 11:16 PM
03/22/16 11:16 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
The answer is no. IIt is not recommended by the factory or carb manufacturers to use Teflon tape on such fittings.
