D series steering box input seal #3230786
05/03/24 09:49 AM
05/03/24 09:49 AM
Bennett, Colorado
Charger69RT8 Offline OP
Bennett, Colorado
I am having trouble obtaining this seal. All parts stores I've contacted so far only have the seal for the 3/4" shaft which to my understanding is '79 & later. What I have is a '76 with a 7/8" shaft. Seals are 1 3/8" O.D. What I've found so far is also smaller on the O.D. Please educate / advise me on what I am missing. Where is this seal available? Or is it?
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
Re: D series steering box input seal [Re: Charger69RT8] #3230801
05/03/24 10:47 AM
05/03/24 10:47 AM
moparx Offline
moparx  Offline
if you can get numbers from the seal, if it's still made by anyone, you should be still able to obtain one from somewhere. [like a bearing house]
i'm thinking this application of seal is possibly used on applications other than steering boxes.
just my personal experience with manufacturing and farming equipment.
beer
Re: D series steering box input seal [Re: moparx] #3230819
05/03/24 01:36 PM
05/03/24 01:36 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yup. I have to "match up" seals all the time especially on the garden tractors and such that I work on...
I was surprised when I bought my 2 post lift there's 14 ball bearings on it... Going by the numbers on them they are the same bearing as a input shaft bearing on a Ford 4 speed Top loader trans... If you have the shaft Diameter and the recess diameter where the outside of the seal rides it can be cross referenced easily
Re: D series steering box input seal [Re: Charger69RT8] #3230830
05/03/24 03:25 PM
05/03/24 03:25 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Go to a bearing supplier. They will measure the old seal (if you have it) and sell you a new one. twocents
Re: D series steering box input seal [Re: Hugh Jorgan] #3230837
05/03/24 04:25 PM
05/03/24 04:25 PM
Bennett, Colorado
Bennett, Colorado
Unfortunately, not that simple. There is an oil seal, a dust seal, and O-ring. I do have the old seals but searching keeps returning links to parts stores and showing the wrong kit (3/4") . None of the web pages show ID & OD. I have found the old Gates number. Gates P/S Repair Kit - 351310 It seems as only Jegs and Ebay have them available at highway robbery prices. Although I did find reasonable price on Ebay, but only available apparently if I create an ebay account.
Jegs Listing
2012 Challenger SRT
69 Charger R/T
Re: D series steering box input seal [Re: Charger69RT8] #3230843
05/03/24 05:11 PM
05/03/24 05:11 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
I bought a rebuild kit from NAPA years back. Did you try them? shruggy
A bearing supplier like Purvis bearing will have all 3 items. twocents
Re: D series steering box input seal [Re: Hugh Jorgan] #3230851
05/03/24 05:41 PM
05/03/24 05:41 PM
Bennett, Colorado
Bennett, Colorado
I have tried Napa. Just like the others they show the 3/4" seal as a fit and is the only one they carry or can order. Had never heard of Purvis, and got excited when I saw a branch here Denver which is reasonable drive time. The gentlemen I spoke with indicated he will see what he can find, but it didn't sound very promising. Thank you for the tip.
2012 Challenger SRT
69 Charger R/T
Re: D series steering box input seal [Re: Charger69RT8] #3230975
05/04/24 11:50 AM
05/04/24 11:50 AM
moparx Offline
moparx  Offline
what number[s] is [are] on the old seal[s] ?
o-rings can be measured easily, and are readily obtained almost everywhere.
beer
Re: D series steering box input seal [Re: Charger69RT8] #3230991
05/04/24 12:52 PM
05/04/24 12:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You are not looking very hard. Seal kit
Re: D series steering box input seal [Re: NITROUSN] #3231122
05/05/24 11:13 AM
05/05/24 11:13 AM
moparx Offline
moparx  Offline
and it even fits fourty'leven different applications...............
beer
Re: D series steering box input seal [Re: moparx] #3231152
05/05/24 01:50 PM
05/05/24 01:50 PM
Bennett, Colorado
Bennett, Colorado
Original seals are IPC 5686526 for the oil seal & IPC 5688229 for the dust seal. You will find them on the web in multiple places all showing discontinued. I did find online the oil seal N.O.S. at a surplus reseller, but no dust seal.
Nitrousin, I had found that and in fact it is in my cart. Rock Auto also carries the same brand & part number. I have not pulled the trigger for this reason. Nothing I've found verifies it as for the 7/8" shaft. I've already been through that long list of applications that it "fits" with Napa, O'Reilly, Advance Auto, & Autozone. They all say they have it and it fits. But when you get hands on it, it is the seal for 3/4" input. The Gates kit I listed before is so far the only verified correct items.
Thank you for the time you spent looking and responding.
2012 Challenger SRT
69 Charger R/T
Re: D series steering box input seal [Re: Charger69RT8] #3231188
05/05/24 05:21 PM
05/05/24 05:21 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Excuse me for asking but is your truck a 2wd, 4wd, 1/2ton, 3/4 or 1 ton?
Re: D series steering box input seal [Re: Hugh Jorgan] #3231224
05/05/24 07:53 PM
05/05/24 07:53 PM
Bennett, Colorado
Bennett, Colorado
2wd 1/2 ton short bed mongrel. I picked it up this way a couple of years ago. It has been put together from more than one. Got two vin plates with it and it had a state issued vin. Because of this, I tried looking up various years, 1/2 ton, 1/4, all ranges of engine sizes, D100 / W100, Amazingly they all come back with the same part number for the seal. As do numerous early and mid 70's chevy cars and pickups. I found one of the Gates kits on a web site catering to 70's camaro's. Don't know if it supply chain issues from the covid mess, or just one of those quantity moving items that is limited in production.
2012 Challenger SRT
69 Charger R/T
Re: D series steering box input seal [Re: Charger69RT8] #3231530
05/07/24 08:43 AM
05/07/24 08:43 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I used Edelmann Seal Kit 7860 for my 76 D100 2wd, It took afew incorrect kits to find one that actually fit mine.
The only Carbs I care about are under the hood!
Re: D series steering box input seal [Re: Azzkikrcuda] #3231553
05/07/24 11:44 AM
05/07/24 11:44 AM
Bennett, Colorado
Bennett, Colorado
Thank you. I see you have been through the same struggle. That is confirmation enough for me to order one.
2012 Challenger SRT
69 Charger R/T
Re: D series steering box input seal [Re: Charger69RT8] #3233093
05/16/24 12:04 AM
05/16/24 12:04 AM
Bennett, Colorado
Bennett, Colorado
Thought I would provide an update. The Edelmann 7860 kit arrived. I measured the input seals and confirmed they are for the larger 7/8" shaft.
Thanks Azzkikr for that number.
2012 Challenger SRT
69 Charger R/T
Re: D series steering box input seal [Re: Charger69RT8] #3233144
05/16/24 11:56 AM
05/16/24 11:56 AM
moparx Offline
moparx  Offline
beer
