D series steering box input seal
#3230786
05/03/24 09:49 AM
05/03/24 09:49 AM
Posts: 284 Bennett, Colorado
Charger69RT8
Bennett, Colorado
I am having trouble obtaining this seal. All parts stores I've contacted so far only have the seal for the 3/4" shaft which to my understanding is '79 & later. What I have is a '76 with a 7/8" shaft. Seals are 1 3/8" O.D. What I've found so far is also smaller on the O.D. Please educate / advise me on what I am missing. Where is this seal available? Or is it?
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
Re: D series steering box input seal
[Re: Charger69RT8]
#3230801
05/03/24 10:47 AM
05/03/24 10:47 AM
Posts: 19,492 north of coder
moparx
if you can get numbers from the seal, if it's still made by anyone, you should be still able to obtain one from somewhere. [like a bearing house] i'm thinking this application of seal is possibly used on applications other than steering boxes. just my personal experience with manufacturing and farming equipment.
[Re: Hugh Jorgan]
#3230837
05/03/24 04:25 PM
05/03/24 04:25 PM
Charger69RT8
Bennett, Colorado
Unfortunately, not that simple. There is an oil seal, a dust seal, and O-ring. I do have the old seals but searching keeps returning links to parts stores and showing the wrong kit (3/4") . None of the web pages show ID & OD. I have found the old Gates number. Gates P/S Repair Kit - 351310 It seems as only Jegs and Ebay have them available at highway robbery prices. Although I did find reasonable price on Ebay, but only available apparently if I create an ebay account. Jegs Listing
[Re: Hugh Jorgan]
#3230851
05/03/24 05:41 PM
05/03/24 05:41 PM
Charger69RT8
Bennett, Colorado
I have tried Napa. Just like the others they show the 3/4" seal as a fit and is the only one they carry or can order. Had never heard of Purvis, and got excited when I saw a branch here Denver which is reasonable drive time. The gentlemen I spoke with indicated he will see what he can find, but it didn't sound very promising. Thank you for the tip.
[Re: moparx]
#3231152
05/05/24 01:50 PM
05/05/24 01:50 PM
Charger69RT8
Bennett, Colorado
Original seals are IPC 5686526 for the oil seal & IPC 5688229 for the dust seal. You will find them on the web in multiple places all showing discontinued. I did find online the oil seal N.O.S. at a surplus reseller, but no dust seal.
Nitrousin, I had found that and in fact it is in my cart. Rock Auto also carries the same brand & part number. I have not pulled the trigger for this reason. Nothing I've found verifies it as for the 7/8" shaft. I've already been through that long list of applications that it "fits" with Napa, O'Reilly, Advance Auto, & Autozone. They all say they have it and it fits. But when you get hands on it, it is the seal for 3/4" input. The Gates kit I listed before is so far the only verified correct items.
Thank you for the time you spent looking and responding.
[Re: Hugh Jorgan]
#3231224
05/05/24 07:53 PM
05/05/24 07:53 PM
Charger69RT8
Bennett, Colorado
2wd 1/2 ton short bed mongrel. I picked it up this way a couple of years ago. It has been put together from more than one. Got two vin plates with it and it had a state issued vin. Because of this, I tried looking up various years, 1/2 ton, 1/4, all ranges of engine sizes, D100 / W100, Amazingly they all come back with the same part number for the seal. As do numerous early and mid 70's chevy cars and pickups. I found one of the Gates kits on a web site catering to 70's camaro's. Don't know if it supply chain issues from the covid mess, or just one of those quantity moving items that is limited in production.
[Re: Charger69RT8]
#3231530
05/07/24 08:43 AM
05/07/24 08:43 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
I used Edelmann Seal Kit 7860 for my 76 D100 2wd, It took afew incorrect kits to find one that actually fit mine.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#3231553
05/07/24 11:44 AM
05/07/24 11:44 AM
Charger69RT8
Bennett, Colorado
Thank you. I see you have been through the same struggle. That is confirmation enough for me to order one.
[Re: Charger69RT8]
#3233093
05/16/24 12:04 AM
05/16/24 12:04 AM
Charger69RT8
Bennett, Colorado
Thought I would provide an update. The Edelmann 7860 kit arrived. I measured the input seals and confirmed they are for the larger 7/8" shaft.
Thanks Azzkikr for that number.
