Gen3 6.4 to A833 flywheel #3229904
04/29/24 08:56 AM
04/29/24 08:56 AM
Austin, TX
V
vrenlos Offline OP
vrenlos  Offline OP
V
Austin, TX
Hi all,
I feel like I'm missing something very elementary here, or making this way more complicated than it needs to be, but I'm planning to put an A833 behind a 6.4l Gen3 Hemi in my 66 Charger. My motor was originally mated to a TR6060, and I still have that stock flywheel. However, I'm open to a new billet one.
That said, I'm planning on the Lakewood Al bell (LK7000) and while shopping for flywheels it seems a lot are marked as right/passenger side starter while others are marked left/drivers, and some don't mention at all. In my mind it seems like the starter spinning the same CW direction should engage with the ring gear teeth similarly regardless of side...so what am I missing? Does it matter?
Re: Gen3 6.4 to A833 flywheel [Re: vrenlos] #3230232
04/30/24 01:31 PM
04/30/24 01:31 PM
Austin, TX
V
vrenlos Offline OP
vrenlos  Offline OP
V
Austin, TX
For those playing along at home, it looks like there's a .375" difference on the ring gear location forward-back (at least on the RAM models). The passenger side version sits flush with the crank flange, and the driver's side version is pushed 3/8 back towards the trans.
Re: Gen3 6.4 to A833 flywheel [Re: vrenlos] #3230435
05/01/24 10:22 AM
05/01/24 10:22 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't know anything about a gen3. My buddy justmoparjoe on YouTube put a gen3 in his 70 Challenger with A833. I think he said the crank wasn't drilled deep enough for the pilot so he had to cut some off and run the ball bearing from O'Riellys for a 95 Ram. Sorry I don't know anything about that kinda stuff.
2011 Drag Pak Challenger
Re: Gen3 6.4 to A833 flywheel [Re: rickseeman] #3230436
05/01/24 10:24 AM
05/01/24 10:24 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think you should put this on the Gen 3 forum.
Re: Gen3 6.4 to A833 flywheel [Re: rickseeman] #3230503
05/01/24 03:26 PM
05/01/24 03:26 PM
Austin, TX
V
vrenlos Offline OP
vrenlos  Offline OP
V
Austin, TX
Thanks Rick! I should hopefully have a transmission and bell in-hand by end of week, so I'll mock it up and start measuring. I'll peruse the Gen3 forum as well.
What really has me scratching my head is the Lakewood bell site states "early truck flywheel required" but that seems to conflict with the 130t mandate...which one is wrong beats me until I have it in hand.
Re: Gen3 6.4 to A833 flywheel [Re: vrenlos] #3230530
05/01/24 06:39 PM
05/01/24 06:39 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Justmoparjoe made it work and has been driving it for years. He may have made a video about it.
Re: Gen3 6.4 to A833 flywheel [Re: rickseeman] #3230729
05/02/24 09:26 PM
05/02/24 09:26 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I put a 833 behind a 6.4 in a 72 Cuda. Get a hold of Brewers. Set me up.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Gen3 6.4 to A833 flywheel [Re: hulmule] #3230945
05/04/24 08:42 AM
05/04/24 08:42 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
"Early", depends on you perspective. For me that would be 172t. But I would assume is 143t, as that is what dodge started using in 1969 on trucks. And 68-69 BB cars. I thought I read the crank flange location was a little different but when using the stock bell it still worked.
