Re: 430hp 440
[Re: Pacnorthcuda]
#3230070
04/29/24 09:33 PM
04/29/24 09:33 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
that's sort of typical of 440 replacement pistons if you don't get the 6 pack piston , better than .180 in the hole smogger piston.
Re: 430hp 440
[Re: elmor353]
#3230112
04/30/24 12:35 AM
04/30/24 12:35 AM
Posts: 3,203 Md.
carnut68
Md.
The 2266F will be .070 in the hole.
America First!
Re: 430hp 440
[Re: BSB67]
#3231017
05/04/24 03:37 PM
05/04/24 03:37 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looks like a good candidate for a Comp XE274 or PP280 cam.
A little bowl work will be worthwhile on either set of heads.
Depending on how good the heads end up, should be close to 400hp.
With something like Stealths, an RPM and DP carb I’d expect a solid 425hp+.
Re: 430hp 440
[Re: fast68plymouth]
#3231117
05/05/24 10:40 AM
05/05/24 10:40 AM
JohnRR
U.S.S.A.
With something like Stealths, an RPM and DP carb I’d expect a solid 425hp+. There you go .... where's the OP ???
Re: 430hp 440
[Re: JohnRR]
#3231186
05/05/24 04:38 PM
05/05/24 04:38 PM
fast68plymouth
So. Burlington, Vt.
One of my old combos: -Re-ringed 1968 short block -346 heads with literally a NAPA store VJ, stock w-upgraded springs, zero porting -Crower 271HDP cam, stock rockers -original Torker/780vs/1” open spacer -moroso under drive pulley -1-3/4 headers -factory 11” high stall converter -4.10’s, 29.5 x 10.5 slicks, SS springs -3575 race weight
Best of 12.12@112 Shift at 5K, thru the lights at 54-5500
With a std performer and a stock bottom pulley it ran constant 12.40’s @110.
I won some $$$ with that combo.
It probably would have been around the 400hp mark on the dyno(the Moroso chart shows 385 for 112mph@3575lbs).
Re: 430hp 440
[Re: B1MAXX]
#3231427
05/06/24 04:13 PM
05/06/24 04:13 PM
fast68plymouth
So. Burlington, Vt.
I believe there is a lot more left. Of course there’s more left. How far you take it depends on what the intentions are for the car. I ran unported 906’s on my 383, which made nearly 500hp with a very basic bottom end. It went low-11’s at over 3600lbs. That doesn’t mean it would have made for a great street cruiser. I stand by my cam suggestions for someone looking for a 440 in the 1hp/ci range……… with the aforementioned DP/RPM/bowl work. With the OP’s intake & carb and no porting it’ll obviously be less. Sure, you can get some of that back by adding a bigger cam, if you’re okay with whatever reduction in street civility that comes with the added duration.
Re: 430hp 440
#3231691
05/08/24 09:28 AM
05/08/24 09:28 AM
Posts: 2,523 God's Country Maryland
GODSCOUNTRY340
Built a stroker 440 with ported 915 heads, 2.14/1.81 valves max wedge rockers, .718 lift Crane roller cam, 12.8 compression. Don't know the horsepower but the 3100 pound Dart ran best of 10.03 at 133 mph with single 1050 carb on a Victor 440 intake. Outran many aluminum headed 440s, they were not happy this factory iron headed 440 was out ETing them.
