USCT Front end lifting tool #3229197
04/25/24 07:54 PM
04/25/24 07:54 PM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
Anybody use this? Do you like it? How long are the square tubing that goes to the bumper mounts?
Thanks!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: USCT Front end lifting tool [Re: A70Runner] #3229267
04/26/24 08:45 AM
04/26/24 08:45 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
How long are the square tubing that goes to the number mounts?
USCT could tell you !!!
Re: USCT Front end lifting tool [Re: A70Runner] #3229277
04/26/24 09:27 AM
04/26/24 09:27 AM
What is that kit suppose to do and on what brand and model cars confused
Re: USCT Front end lifting tool [Re: Cab_Burge] #3229301
04/26/24 11:16 AM
04/26/24 11:16 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Presumably, USCT is answering their phone or email, or has the dimensions on their website, but that may not be the case.
Cab, that's to lift the front of the car using an engine hoist:
Top bar is hooked to the hoist as a crossbar, lower bars mount to frame rail bumper bracket holes & slide into top bar.
I would think USCT is smart enough that it fits any unibody Mopar; note various attachment holes.
Some guys make their own, and it's a common method if one lacks a lift.
Re: USCT Front end lifting tool [Re: topside] #3229313
04/26/24 01:18 PM
04/26/24 01:18 PM
BDW Offline
BDW  Offline
I'm cheap, couldn't you do the same thing with some 2x4's?
Re: USCT Front end lifting tool [Re: BDW] #3229325
04/26/24 02:04 PM
04/26/24 02:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
You do it and let us know how it works out !!!
Re: USCT Front end lifting tool [Re: Stanton] #3229329
04/26/24 02:12 PM
04/26/24 02:12 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
I used some 1/4" thick angle iron. 1/8" thick angle was more than adequate for lifting the car by itself. It showed some flexing when lifting the front end with the engine/trans installed though, so I upgraded to the 1/4".
Re: USCT Front end lifting tool [Re: burdar] #3229337
04/26/24 02:46 PM
04/26/24 02:46 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
If anyone is looking for that engine/trans k member dolley hit me up.... will be selling mine.... done with big restos
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: USCT Front end lifting tool [Re: Stanton] #3229345
04/26/24 04:35 PM
04/26/24 04:35 PM
BDW Offline
BDW  Offline
Originally Posted by Stanton
Quote
Thx for the well thought out and helpful reply.
Very refreshing
Re: USCT Front end lifting tool [Re: BDW] #3229353
04/26/24 05:36 PM
04/26/24 05:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Very refreshing
Use plenty of nails !!
Re: USCT Front end lifting tool [Re: Stanton] #3229445
04/27/24 09:41 AM
04/27/24 09:41 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I built mine from square tubing also . . . my welding skills got better after building this (ha ha ha), but it held up fine. Made it with the dolly wheels so I could roll it around on the cradle, then when going to put in engine/trans, just turned it 90 deg to lift car.
Re: USCT Front end lifting tool [Re: a12rag] #3229446
04/27/24 09:41 AM
04/27/24 09:41 AM
a12rag Offline
a12rag  Offline
more pics for ya
Re: USCT Front end lifting tool [Re: a12rag] #3229500
04/27/24 01:31 PM
04/27/24 01:31 PM
moparx Offline
moparx  Offline
3/16x2 or 1/4x2 angle will work fine.
as to the length needed for the bumper mounting points, just go about 1 1/2" past the rear most bumper mount bolt center point and that will work.
beer
Re: USCT Front end lifting tool [Re: JMCFAN] #3229520
04/27/24 03:06 PM
04/27/24 03:06 PM
CA
crackedback Offline
crackedback  Offline
CA
I did the same thing...
3 pieces of angle with holes drilled in them. simple and inexpensive solution that works on A/B/E cars.
Yes, they can be made out of wood, not my preferred method.
Re: USCT Front end lifting tool [Re: a12rag] #3229600
04/27/24 10:19 PM
04/27/24 10:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not trying to be a jerk but those welds are colder than the Antarctic eek. get some more HEAT on those if you use them again wink beer
Re: USCT Front end lifting tool [Re: TJP] #3229657
04/28/24 09:08 AM
04/28/24 09:08 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
When my brother put his engine in, he just used the car's bumper brackets along with a 2x4 crossbar bolted to them. The bumper brackets lifted the car while the 2x4 was just to keep the loops of chain from potentially slipping off. Worked just fine.
Re: USCT Front end lifting tool [Re: TJP] #3229699
04/28/24 11:32 AM
04/28/24 11:32 AM
moparx Offline
moparx  Offline
i agree about those welds as well.............
any time i weld two flat pieces of material together, one on top of the other, i also drill a couple of holes and plug weld them. just as a safety catch if something happens.
beer
Re: USCT Front end lifting tool [Re: EV2RTSE] #3229851
04/28/24 10:09 PM
04/28/24 10:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You should sell those on Ebay 🤣🤣
