273 318 dual quad #3228375
04/21/24 08:36 AM
04/21/24 08:36 AM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
This is on Facebook Book Market place. It's interesting a factory Mopar air cleaner fits on this set up.
Screenshot_20240417-174154.pngScreenshot_20240417-174037.pngScreenshot_20240417-174057.png
Keep old mopars alive.
Re: 273 318 dual quad [Re: 2boltmain] #3228511
04/21/24 10:47 PM
04/21/24 10:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
that is rather interesting beer just an FYI the early 273's used a different intake than the 318's
Re: 273 318 dual quad [Re: TJP] #3228518
04/21/24 11:11 PM
04/21/24 11:11 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Yep, I believe drilling the mounting holes a bit larger diameter solved that problem, it seems to me the threaded holes in the 273 and the 318 heads were at a slightly different angles. Opening up the holes on the intake allowed the bolts to be threaded into the heads and the slight difference in the angles didn't cause any sealing issues. But it was a long time ago.
Re: 273 318 dual quad [Re: poorboy] #3228531
04/22/24 12:21 AM
04/22/24 12:21 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Isnt the D66 version the 318 up pattern?
STOP POTATO HATE!
Re: 273 318 dual quad [Re: poorboy] #3228727
04/23/24 10:30 AM
04/23/24 10:30 AM
moparx Online content
moparx  Online Content
also, didn't the early 273's use 5/16" bolts as opposed to the 318 using 3/8" bolts ?
i may be wrong on this, not that i have been wrong in the past...... biggrin
if so, will someone please correct me ?
beer
Re: 273 318 dual quad [Re: moparx] #3228789
04/23/24 01:56 PM
04/23/24 01:56 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
The setup on my 64 Dart
Abe Lincoln
Re: 273 318 dual quad [Re: dart4forte] #3228802
04/23/24 05:22 PM
04/23/24 05:22 PM
Holland MI Ottawa
2
Holland MI Ottawa
Dart4forte that is a wonderful looking engine.
Re: 273 318 dual quad [Re: poorboy] #3229025
04/24/24 09:40 PM
04/24/24 09:40 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Exactly right, that's how I put a Performer intake on my 65 273.
Re: 273 318 dual quad [Re: Sniper] #3229092
04/25/24 10:39 AM
04/25/24 10:39 AM
did the performer intake have the small ports ? what size did you drill the holes to ? did you use washers under the bolt heads ?
beer
Re: 273 318 dual quad [Re: moparx] #3229261
04/26/24 08:03 AM
04/26/24 08:03 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
I don't recall the port match, I don't worry about it, it's turd polishing for a stock 273 in my opinion, lol.
I don't recall the size drill bit I used, wasn't much bigger than the stock opening as someone mentioned the intake bolts are smaller on the early 273 and there was almost enough clearance as it was, just did a test ft and inspection while it was on the stand.
I always use washers, so yes, but not so much because of anything specific to this swap.
