273 318 dual quad
#3228375
04/21/24 08:36 AM
04/21/24 08:36 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
This is on Facebook Book Market place. It's interesting a factory Mopar air cleaner fits on this set up.
Keep old mopars alive.
Re: 273 318 dual quad
[Re: 2boltmain]
#3228511
04/21/24 10:47 PM
04/21/24 10:47 PM
Posts: 15,355 Omaha Ne
TJP
Omaha Ne
that is rather interesting just an FYI the early 273's used a different intake than the 318's
[Re: TJP]
#3228518
04/21/24 11:11 PM
04/21/24 11:11 PM
Posts: 10,558 Freeport IL USA
poorboy
Freeport IL USA
that is rather interesting just an FYI the early 273's used a different intake than the 318's Yep, I believe drilling the mounting holes a bit larger diameter solved that problem, it seems to me the threaded holes in the 273 and the 318 heads were at a slightly different angles. Opening up the holes on the intake allowed the bolts to be threaded into the heads and the slight difference in the angles didn't cause any sealing issues. But it was a long time ago.
[Re: poorboy]
#3228727
04/23/24 10:30 AM
04/23/24 10:30 AM
Posts: 19,396 north of coder
moparx
that is rather interesting just an FYI the early 273's used a different intake than the 318's Yep, I believe drilling the mounting holes a bit larger diameter solved that problem, it seems to me the threaded holes in the 273 and the 318 heads were at a slightly different angles. Opening up the holes on the intake allowed the bolts to be threaded into the heads and the slight difference in the angles didn't cause any sealing issues. But it was a long time ago. also, didn't the early 273's use 5/16" bolts as opposed to the 318 using 3/8" bolts ? i may be wrong on this, not that i have been wrong in the past...... if so, will someone please correct me ?
[Re: poorboy]
#3229025
04/24/24 09:40 PM
04/24/24 09:40 PM
Posts: 6,241 nowhere
Sniper
nowhere
Exactly right, that's how I put a Performer intake on my 65 273.
[Re: Sniper]
#3229092
04/25/24 10:39 AM
04/25/24 10:39 AM
moparx
Exactly right, that's how I put a Performer intake on my 65 273. did the performer intake have the small ports ? what size did you drill the holes to ? did you use washers under the bolt heads ?
[Re: moparx]
#3229261
04/26/24 08:03 AM
04/26/24 08:03 AM
Sniper
nowhere
Exactly right, that's how I put a Performer intake on my 65 273. did the performer intake have the small ports ? what size did you drill the holes to ? did you use washers under the bolt heads ? I don't recall the port match, I don't worry about it, it's turd polishing for a stock 273 in my opinion, lol. I don't recall the size drill bit I used, wasn't much bigger than the stock opening as someone mentioned the intake bolts are smaller on the early 273 and there was almost enough clearance as it was, just did a test ft and inspection while it was on the stand. I always use washers, so yes, but not so much because of anything specific to this swap.
