Found the trans spag issue, bolt on piston, and now this #3228280
04/20/24 01:53 PM
04/20/24 01:53 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
What's the chance of looking up and seeing this? Guess it's time to try the other cam I have.
Doug
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228287
04/20/24 02:12 PM
04/20/24 02:12 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Damn Doug, I think god is saying take that engine apart and overhaul it.
Re: Found the trans spag issue, bolt on piston, and now this [Re: 71Demon528] #3228292
04/20/24 02:24 PM
04/20/24 02:24 PM
moparx Offline
moparx  Offline
seems like you just can't get a break with this two week deadline !
glad those problems were found !
beer
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228318
04/20/24 05:59 PM
04/20/24 05:59 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Yes very dissappointing , but think if you didn't see it & kept running it . Very good catch there Doug . Hope the other cam works out without too much change . Gary
Re: Found the trans spag issue, bolt on piston, and now this [Re: Gabby63] #3228329
04/20/24 07:39 PM
04/20/24 07:39 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It's all apart. Right around 200 passes since the rod bearing failure. New crank, rods, pistons, jessel belt, valves, locks, springs, valve job, new lifter bushings, rings, bearings, crank scraper, and oil pump guts. In my notes on the build at the end of 2021; " #5 intake has a pit in the lobe. " Apparently the heat treat on the surface has degraded further. The current cam has 1718 int and 1862 exh lobe on 112 lca, 4/7 swap. The cam in hand has 1719 int and 1864 exh on 111, std firing order. So .022' more int lift, 4 degrees more exh duration. Same lobe designs. The lifter wheel apears to be undamaged. I'll check but it had tons of piston to valve and some room left on coil bind as well.
Doug
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228357
04/20/24 11:29 PM
04/20/24 11:29 PM
Is that the opening or closing side of that ramp?
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228364
04/21/24 02:17 AM
04/21/24 02:17 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
So engine is out and totally apart? Or just enough to do the cam swap?
Re: Found the trans spag issue, bolt on piston, and now this [Re: 71Demon528] #3228372
04/21/24 07:45 AM
04/21/24 07:45 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It's in the car. Pan is still off. The other issue is the screen windage tray is cracked, again. It has a very nice crank scraper. I'd like to leave the screen out. But make a baffel to shield the oil pick-up from the "line of sight" to the crank. Something like this.
Doug
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228405
04/21/24 01:06 PM
04/21/24 01:06 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Doug
Dang, wonder what’s causing the screen to break. I have same crank scraper from Ishihara Johnson. Very nice piece.
Re: Found the trans spag issue, bolt on piston, and now this [Re: 71Demon528] #3228452
04/21/24 06:39 PM
04/21/24 06:39 PM
PA
moparacer Offline
moparacer  Offline
PA
Doug
The oil beating off of it at 7000 RPM doesn't help.
DW you are giving me flashbacks with all these problems. The cam, yup been there. The gaskets, yup been there, the windage screen, yup been there.
Not with big blocks, because I will never used a screen in one, but my small blocks with race pans and screens back in the day, I had screens crack.
That setup you have with the carboard covering the pickup will be fine I think.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228585
04/22/24 12:11 PM
04/22/24 12:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Another good catch.
I've seen similar failure on wheel bearings and U joints before but not a camshaft.
Is the general feeling that the pitted area sort of "spread" over time, for lack of a better word?
Rich H.
Esse Quam Videri
Re: Found the trans spag issue, bolt on piston, and now this [Re: ZIPPY] #3228594
04/22/24 01:10 PM
04/22/24 01:10 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Good catch Doug.
I tried to buy one of those crank scrapers. Gave them my info, card number... "It will be a few weeks." Never heard from the guy again...
69 GTX 68 Road Runner
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228595
04/22/24 01:16 PM
04/22/24 01:16 PM
an8sec70cuda Offline
Doug...I had the same issue in 2021 w/ an Isky hydraulic roller. Was in a good friend's boat with a 440" sb chevy. The cam had been run roughly 5 summers, but not a ton of run time. I'd built it originally in 2016.
It had 3 lobes that looked like yours when I took it apart. They also said bad heat treat.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Found the trans spag issue, bolt on piston, and now this [Re: an8sec70cuda] #3228883
04/24/24 07:47 AM
04/24/24 07:47 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Kevin at IJ crank scrapers has a fix for the cracked screen, He was gracious enough to text back and forth on Sunday afternoon. Later sending me a conformation # and shipping the supplies at N/C. Great service. Ordered one pair of lifters from Isky as I wasn't sure I could send mine back for repair and get them by next weekend. Cleaned up the cam and installed it in a spare 440 block. Modified the degree wheel to bolt to the cam. Set up the dial indicator and mapped the cam out to make sure it was what the numbers on the cam said were correct. A little mind game figuring out the cam with no crank installed for TDC. Along with the fact that all the numbers were reduced by 2. I started by finding the int C/L and working backwards. It all looks good. The int lobe base circle is .030" smaller, exhaust .015" smaller. At the last build every spring was checked for coil bind. For some reason the springs with the greatest coil bind height are all on the intakes. So I'll move them around at the .024 extra lift gets it a little close. Tetsing next wednesday. Racing next weekend.
Doug
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3228893
04/24/24 09:37 AM
04/24/24 09:37 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Doug
It would be great if you can deburr/detail then paint the mock-up block. apimp
Re: Found the trans spag issue, bolt on piston, and now this [Re: HardcoreB] #3229417
04/27/24 07:12 AM
04/27/24 07:12 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Got the springs all swapped. 8 springs checked about .025" less coil bind than the others. They all went on the intakes. Checked all the lifter wheel play with a slick homemade tool from Hardcore. Everything cleaned. Cam is in at 108 C/L, .050"-.060" to coil bind. Rocker ratio is little over 1.72. Lift came out to .837/.810 w/o lash on checking springs. Piston to valve .075 int, .110. Borrowed a very nice LSM on the motor spring tester. Found the #8 exhaust spring about 35 lbs low. I have spares so that'll get swapped. Today I'll get the windage screen fabbed up, install the pan and steering linkage, radiator, alternator, add oil, trans fluid, and coolant. Still waiting on the lifter. It can be installed thru the distributor hole. So if It takes to much longer the valley inspection cover, intake, and carbs will all get installed. Wesnesdays weather looks good. Going to try and test before next weekends first race.
Doug
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3229829
04/28/24 08:34 PM
04/28/24 08:34 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Just waiting for the lifter. Ordered Monday, supposed to be here Tuesday. The lifter will fit thru the distributor hole. With
a litle work using tig wire it can be installed with the valley tray and intake in place. Moved the trans breather. It's always been lower than the trans. Located just in front of the rear license plate. Never overflowed, but t didn't vent as well as it should. And just for Hardcore B instead of wasting time detailing the test block. The undercarriage got cleaned and waxed. Along with the engine.
Doug
Re: Found the trans spag issue, bolt on piston, and now this [Re: dvw] #3229837
04/28/24 08:59 PM
04/28/24 08:59 PM
gregsdart Offline
gregsdart  Offline
Super clean ride you built, Doug! And performance to match!
Re: Found the trans spag issue, bolt on piston, and now this [Re: gregsdart] #3229885
04/29/24 06:47 AM
04/29/24 06:47 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Way to hustle DVW! Looking forward to a good year!
Re: Found the trans spag issue, bolt on piston, and now this [Re: HardcoreB] #3230567
05/01/24 11:04 PM
05/01/24 11:04 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Recieved the lifter from UPS at 4:30 yesterday. Made test passes at Milan today. No hero numbers but it was deadly consistent. It was pretty windy. Track prep was great. Had the front shocks full tight to keep from 60 ft with the rear wheels. What a whirlwind 10 days.
Doug
