'62 Dart 440 Tail Lights/ Backup Lights #3206035
01/18/24 08:57 PM
01/18/24 08:57 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Dumb question.
On the back of a '62 Dart 440 I believe the lower lights are the taillight/brake lights and the upper lights are back up lights, correct???
I think I've seen all four with red lenses and I've seen the top two with metal block-off plates but I assume those cars may not have been 440's.
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3206061
01/18/24 11:07 PM
01/18/24 11:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3206062
01/18/24 11:08 PM
01/18/24 11:08 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Your OEM assumption is correct.
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: jcc] #3206066
01/18/24 11:32 PM
01/18/24 11:32 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks guys.
Now the hunt begins for the lenses...
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3206069
01/18/24 11:58 PM
01/18/24 11:58 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
This is the picture that confused me...
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3206074
01/19/24 12:25 AM
01/19/24 12:25 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Backup lamps were optional in that era.
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: topside] #3206216
01/19/24 02:26 PM
01/19/24 02:26 PM
moparx Offline
moparx  Offline
i like the ones with four red tail lights best ! boogie
beer
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3206375
01/19/24 10:49 PM
01/19/24 10:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I considered reversing mine, but too much work for what gain?
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: moparx] #3206378
01/19/24 10:59 PM
01/19/24 10:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
iagree
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: TJP] #3206401
01/20/24 12:10 AM
01/20/24 12:10 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That would be only I believe a Polara 500, for the record.
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3206405
01/20/24 01:26 AM
01/20/24 01:26 AM
AndyF Offline
AndyF  Offline
Back up lights should be lower to the ground, and tail lights should be up high for visibility. But I don't think the guys at Chrysler were thinking like that in '62
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: jcc] #3206546
01/20/24 03:38 PM
01/20/24 03:38 PM
moparx Offline
moparx  Offline
i believe you are correct.
however, didn't the tail light and back up light bezels have the same mounting bolt patterns, so if one was so inclined, he could replace the back up light housing with a brake light housing so as to end up with four red tail lights ?
or maybe just swap the back up light lenses with red ones ?
i have four red assemblies on the shelf i picked out of a used car lot that went out of business over 50 years ago, and these came from the lot's junkyard in the field directly behind the lot.
i can't remember if they were from the same car or not.
beer
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: moparx] #3207358
01/22/24 11:19 PM
01/22/24 11:19 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
beer
PM sent.
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: moparx] #3207680
01/23/24 11:46 PM
01/23/24 11:46 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
beer
They are not the same. The bolt patterns are though.
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: jcc] #3228003
04/19/24 01:22 AM
04/19/24 01:22 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Sometime in the past someone "re-wired" the truck wiring harness and wired all four lights as turn/brake lights. I'll have to see what it will take to wire the backup lights back in.
The backup lenses and tail/brake lenses are interchangeable, correct?
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: VITC_GTX] #3228020
04/19/24 08:44 AM
04/19/24 08:44 AM
Minn
SportF Offline
SportF  Offline
Minn
I've got these. I'll be in the midwest at races this summer, where are you from?
Re: '62 Dart 440 Tail Lights/ Backup Lights [Re: SportF] #3228064
04/19/24 12:03 PM
04/19/24 12:03 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
PM sent
