Clutch problems #3227603
04/17/24 05:41 AM
04/17/24 05:41 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve got a customer looking for a new clutch. Diaphram type clutches are not what I’m looking for. I’ve had to many complaints about the different ratio of the Chevy style diaphram with the Mopar ratio. He’s got a Ram Borg and Beck style clutch right now and the release is perfect. The problem is it slips some at high rpm under a load. I’ve used the old Chrysler green back for years in my car with no complaints. It does not slip with a hard shift. It does have the rollers in the clutch that load the clutch with centrifugal force at high rpm. I have a buddy that has a 528 hemi with a twin disc McLeod and it works great. It is a Long style Ford cover. Anyone out there know of a good clutch that’s either a Borg and Beck or Long style that works?
Re: Clutch problems [Re: fastmark] #3227615
04/17/24 07:41 AM
04/17/24 07:41 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
What diam.? I have the 10.95 set up in my car I went down the road of putting 10.5 on because of the bolt pattern but had better luck with the 10.95, even over the green clutch.
Re: Clutch problems [Re: B1MAXX] #3227821
04/18/24 06:15 AM
04/18/24 06:15 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
It’s a 11” currently but it could handle the 10.5 or 10.95 because of the dual bolt pattern on the flywheel.
Re: Clutch problems [Re: fastmark] #3227854
04/18/24 10:07 AM
04/18/24 10:07 AM
VA
dragon slayer Offline
VA
What was the green clutch? The 10.5 and 10.95 use the same bolt pattern no? The 11" had the larger diameter bolt pattern.
Re: Clutch problems [Re: dragon slayer] #3227882
04/18/24 12:16 PM
04/18/24 12:16 PM
Apollo, PA.
Apollo, PA.
mopar race pressure plate 10.5...I had better luck with the extra 1/2 though. (10.95) If your having problems with the 11 you might need a whole different set up (multiple disc)
Is it just time for replacement when I raced my four speed car weekly a clutch set up wouldn't last a hole year before starting to slip. Would do about 2 a season.
Re: Clutch problems [Re: B1MAXX] #3227895
04/18/24 01:17 PM
04/18/24 01:17 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Mcleod makes good clutches. Look at Brewers website
Re: Clutch problems [Re: Cuda340] #3227935
04/18/24 04:43 PM
04/18/24 04:43 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Try to find an old Borg and Beck Mcleod 360153 pressure plate and send it to Mcleod. They will rebuild it. Those were good pressure plates that they don't make anymore.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Clutch problems [Re: 70sixpkrt] #3228038
04/19/24 11:03 AM
04/19/24 11:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wish they still made the Combo PP , B+B hat with Long fingers , I have a 10.95 version in the Dart and I really like it .
To The OP if seeking used clutches I'd also be in the lookout for one of their combo Pressure plates ...
Re: Clutch problems [Re: JohnRR] #3228207
04/20/24 06:27 AM
04/20/24 06:27 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This is a brand new Ram pressure plate from Summit on a freshly built stock 440 Charger RT. The original green back is a 10.5. He pulled out a centerforce diaphragm because it had a poor release. I’ve got a buddy with a 528 hemi and he uses a twin disc McLeod with long fingers. It holds that monster just fine. I don’t think they make that anymore, either.
