Chevy starter question #3228009
04/19/24 06:20 AM
04/19/24 06:20 AM
Port Huron, Michigan
MI_Custumz Offline OP
I have a small block in my 70 Monte. Ever since I bought it 18 years ago, the starter needed to be given a jolt of juice once in a while. The previous owner had a jumper wire from the fuse block to the starter solenoid with a switch under the steering column to give it juice when needed. It has a good battery, starter doesn't make any funny noises, but sometimes it's just nothing at all (no click, grinding, nothing). I have replaced the battery cables and have tested the voltage at the battery and the starter end of it, both about the same. I think I tested it with the key on as if it was starting when I had the starter out last time to replace cables and it was real close there too. Do the solenoids go bad and if so, are they replaceable without replacing the entire starter? I know I could go with a new starter or mini one, but I was thinking maybe the solenoid may have an internal issue with the flow of power since it starts every time I hit the switch on the inside of the car. I'll have to admit, it is nice to have it not start with the key alone sometimes. It's like an anti theft device, but would like to see if I can fix it easily.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228011
04/19/24 06:32 AM
04/19/24 06:32 AM
After a cup of coffee, I thought maybe it could be the ignition wire having an issue as well. I don't remember if I tested that when I had the starter out. I may test that next at the neutral safety switch in the console and again at the starter.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228015
04/19/24 08:06 AM
04/19/24 08:06 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Number 1 issue is undersized wiring leading to low voltage causing slow or no crank.
But, if you get nothing, neutral switch or ignition switch are suspected. They could be worn or in need of adjustment.
Angry white pureblood male
Re: Chevy starter qeustion [Re: ruderunner] #3228032
04/19/24 10:40 AM
04/19/24 10:40 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You can jumper around both the neutral safety switch and ignition switch to eliminate them as the problem. However, since this appears to be an intermittent issue, that may not resolve anything during testing. Maybe next time it is acting up you can do the jumpering and see what changes..
Yes, solenoids can go bad.
Yes, they can be replaced.
However, it might be time to just up and buy a nice, shiny all new one and stop farting about with something that is old. Unless it's some sort of all original car that is and if it is rebuilding your old solenoid might be an idea to consider. No kits that I know of to do that, however, it can be done.
Well, dang, they do make a rebuild kit for your solenoid, assuming it is the original starter. Rock Auto has them. I;m used to old flathead mopars and no one makes kits for those. You have to hand wind your own, lol.
Re: Chevy starter qeustion [Re: Sniper] #3228040
04/19/24 11:04 AM
04/19/24 11:04 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, back in the day, a failed solenoid on a GM starter was not uncommon, and they are replaceable.
They were pretty chap back then, but we'd pull the starter to do that anyway.
Also damaged wiring, loose cable, etc.
If it's the original starter & solenoid, 54 years is a good long run.
But it's just as likely to be in the wiring to the solenoid.
Re: Chevy starter qeustion [Re: Sniper] #3228050
04/19/24 11:20 AM
04/19/24 11:20 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What used to be, and what currently is may be completely different these days, but you used to be able to replace the solenoid on the old GM starters. You have to remove the starter from the car to replace the solenoid.
That said, I have to wonder if since someone ran a wire down to the starter, if the problem lays elsewhere (unless the starter is a royal pain to change). I'm betting the extra wire you spoke of bypasses everything between the battery and the starter. Someone didn't know how to chase down the problem, or couldn't find the problem, so they just added the extra wire. It is possible that simply replacing the extra wire with another will make it work "like it always has".
Personally, if it was mine, I'd replace the starter as a starting point, if its still the original, its spent a lot of time just sitting, or it could be completely wore out. You will have to pull it out to do just about anything with it, I probably would not put that old starter back in without a complete rebuild unless you know its full history. We have places in our town that actually rebuild the old starters and alternators, might be better then the new Chiniseum stuff on the market these days.
Re: Chevy starter qeustion [Re: poorboy] #3228070
04/19/24 12:10 PM
04/19/24 12:10 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Number one problem when a GM starter just clicks and doesn't turn over is the solenoid. Number two problem when that happens is bad brushes. If you can rap the starter with a hammer and it cranks over, suspect it needs brushes. A jumper wire will cover up a lot of sins by delivering more voltage which just covers up the problem, but doesn't solve it. Either way, I'd rebuild the original starter if you want reliabilty, since many parts store rebuilds are carp. Another solution is replacing the old starter with a brand new super small PMGR starter. There are many later model cars that use them and older cars can be retrofitted, especially if the car or truck in question has a HEI distributor. The PMGR starters usually require different starter specific bolts, due to the starter having metric size mounting holes and the block having US spec threads. Some starters come with the needed bolts, some don't. Number of teeth on flywheel/flexplate determines whether a straight across or angled bolt pattern is used. Here's a PDF on Remy starters that can be interchanged.
Linky -->PMGR Remy Chevrolet starter info.
A 1970 Monte Carlo came with points, and a PMGR starter that has the "R" terminal would be needed. If the distributor has been replaced with an HEI, the "R" terminal on the starter is not needed.
Re: Chevy starter qeustion [Re: poorboy] #3228126
04/19/24 05:00 PM
04/19/24 05:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If it works everytime with the bypass wire, I would say you have a switch or wiring issue.
GM's typically use a purple wire form the Ign. switch directly to the solenoid to energize it.
When the solenoid energizes it pulls a shorting contact forward that send battery power to the starter motor and on PRE HEI cars battery power to the coil bypassing the points resistance wire for starting. It also sends the Starter Bendix back to the flywheel engaging the teeth before the SM starts turning.
Energizing the solenoid is audibly noticeable. So while it is possible the solenoid is at fault, I would suspect the switch or wiring first.
twocents beer
Re: Chevy starter qeustion [Re: TJP] #3228127
04/19/24 05:13 PM
04/19/24 05:13 PM
I know it's not a heat soak issue, although that may have contributed to the problem, because I get nothing even after it sits for days. I have new cables as of last year. It is a purple wire to the solenoid along with the one hooked to the fuse box. The ignition switch on the column is new last year or the year before. Neutral safety switch hasn't been replaced or isolated yet. I was going to take the console lid off to tinker with that one day. Should be able to see which one is hot when I turn it to start and go from there as far as voltage. If I connect the hot wire when starting to the wire going to the solenoid with a jumper wire, that should tell me if it's the wiring or switch by checking voltages and isolating the switch. I'm not real mechanical, so this is going to be something I may ask more on. It's not an original starter, but works fine when I hit the button for the fuse panel power to it. I kind of don't want to replace the starter because I'm not sure how to shim it if it needs to be shimmed. Removing and replacing parts is fine as long as they match up old and new.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228150
04/19/24 07:59 PM
04/19/24 07:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Chevy starter shims are made to be swapped without dropping the starter. It is done by removing the outer bolt and loosening the inner one. The shims are open on the inner end and have a bolt hole on the outer. The idea is for the starter to engage without grinding. https://www.amazon.com/chevy-starter-shims/s?k=chevy+starter+shims
Re: Chevy starter qeustion [Re: stumpy] #3228157
04/19/24 08:29 PM
04/19/24 08:29 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Starter shim gap is set by sliding the allen wrench that comes with a new starter between the flex plate teeth, and the starter gear shaft on the flat parts of the wrench with the starter torqued to spec. Many people don't do this, or don't understand how to so they skip it only to get bit by it later. The starter should not make any strange sounds if the gap is set properly. You may have to cut shims in half to get where you need to be. Some instructions will show what the incorrect gaps look like, and on which side of the starter the shims need to go if it comes down to doing the half shim thing.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228183
04/19/24 10:39 PM
04/19/24 10:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
being an "Automagic" try moving the shifter by jiggling in park or try Neutral. If it magically starts it is likely the NS Switch or it needs adjusting. Disconnecting the output wire to the starter and using a test light is helpful wink
keep us posted beer
Re: Chevy starter qeustion [Re: TJP] #3228210
04/20/24 06:49 AM
04/20/24 06:49 AM
I just seem to think the worse in things. Hoping if I need a new starter, that it won't need shimmed. If it does, I'll take it slow and easy and ask questions (sometimes hard for me to do) for answers. I have tried it in neutral and jiggled the handle. None of that seems to make a difference. I'll jiggle it tonight if it won't start. Daughter wants to take senior prom pictures with it. Don't want to tear anything apart tonight. She would be very upset.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228355
04/20/24 11:22 PM
04/20/24 11:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A trick we have done in the past is to swap the starter end to the replacement unit which maintains the original engagement with the flywheel.
If so inclined to verify the solenoid is the issue, one could easily run a temporary wire from the start terminal to a small light inside the car. this would Verify if the Voltage is getting to the terminal or not . if not you know your problem is elsewhere beer
Re: Chevy starter qeustion [Re: TJP] #3228367
04/21/24 06:56 AM
04/21/24 06:56 AM
I do recall having someone turn the key when I was under it replacing the battery cables. I had power to the ignition wire at the solenoid, but don't recall if I checked voltage. I tried to start it for prom pictures and nothing. Jiggled the shifter, tried it in neutral, and still nothing. Hit the button and fired right up. We drove it for pics and moved it around to a few different spots in the park and then she took it to dinner where I swapped out cars. Fired up each time with just the key after the initial no start issue. I do have a couple jumper wires with alligator clips on each end I can hook to the start terminal and to a test light and/or multi meter and either run it to the inside of the car or use an extra security camera I have to watch it live so the jumper wires aren't needed to be extended to the inside of the car. Daughter usually helps with things like this, but she's been living at her mom's the past few months. I appreciate all the suggestions and keeping it in simple terms.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228512
04/21/24 10:54 PM
04/21/24 10:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
do be aware that current and V are two different things. So you may have enough of both for a light bulb,
but Not enough Current for the solenoid. This is Why I suggested a wire off the Start terminal to a bulb inside the car.
If you have a flakey connection that is not passing enough current for the solenoid the bulb will be very dim or not light at all. Hope this makes sense wink
keep us posted beer
Re: Chevy starter qeustion [Re: TJP] #3228546
04/22/24 06:54 AM
04/22/24 06:54 AM
keep us posted beer
I pulled the cover off the console to get to the NSS. I only got a few things tested because I had other things I had to get done around the house. I had a test light that lit up pretty good for power to the one purple wire, so safe to say that's the power from the ignition and the other purple is going to the solenoid. I got 11.96V when the key was in the start position. My next steps will be to put the wires back on and hopefully it won't start so I can check the other purple wire in the console. I will also check the reverse lights for power and voltage just like the ignition one to make sure they are the same since the reverse lights work. Should tell me if the start portion is bad I'm hoping. If It doesn't start, I'll use the jumper wire to bypass the switch. If the NSS needs replaced, is there any alignment issues I need to look at like the ignition switch on the column? I know I probably don't need to check the reverse lights since they work, but I like to know how things work. I'm thinking key on and shifter in reverse should turn on the reverse lights. It should also light them up in any position if I jump those together as well right? Same concept as the ignition wire. If the ignition wire is bad to the starter, I'm hoping to connect a wire to the purple and just pull it through to the starter. Will have to take the wire off the starter to test it as well, but just thinking out loud.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228640
04/22/24 07:23 PM
04/22/24 07:23 PM
Went out to tinker with it again today. I used a pair of thin pliers to jump the reverse light wires while they were off the neutral safety switch. I wasn't a fan of trying to hold onto a wire just in case. That worked like it should, so I knew the method would work for bypassing the NSS to start it. I used the multi meter to check continuity on the reverse and ignition tabs. All is well there as far as I can tell, the multi meter beeped. I put the ignition wires back on the NSS and tried to start it. Nothing, but I was glad that way I could try to test the other wire for power after the switch since I already knew the power was good going to the switch. The test light lit up, but couldn't get a multi meter reading. Too tight of a space. I put in a thin wire in the back of the connections and used the test light to see if it would read. Yup, lit the light up and got a voltage reading. The reading was real close on both connections. It still wouldn't start. I removed the connector and tried jumping it with pliers like the reverse connectors. Nothing. I used the button from the fuse panel power, and it fired up. I am not sure where the wire from the NSS to the solenoid goes, but the next step is to see if it has any power or voltage at the starter. Going to put it on jack stands so I don't have to start it and check more stuff when I get a chance. I was going to remove the wires from the solenoid and see if the ignition one has power and voltage and test the fuse box one. That should tell me if it's the ignition wire from the NSS to the solenoid I hope. I am also hoping it won't start and I can test light the wire on the solenoid. Keep the ideas coming as I appreciate all the help and enjoy tinkering with it, even if I do get frustrated a bit here and there.
Re: Chevy starter qeustion [Re: MI_Custumz] #3228678
04/22/24 11:23 PM
04/22/24 11:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
keep in mind, if you disconnect the purple wire at the starter, You may have voltage with little or no load
The test light on the Start terminal will expose whether the CURRENT is there along with the Voltage
beer
Re: Chevy starter qeustion [Re: MI_Custumz] #3228692
04/23/24 02:15 AM
04/23/24 02:15 AM
Where is this car driven? If east of the Rockies Mtns. does it have rusted floors and frames?
If so check all the grounds to make sure their really good wrench scope, most people don't know that all the current coming out of any and all batteries comes out the negative side and then flows through the circuit back o the positive lead to the battery, not vice a versa like most people think tsk
Good luck, let us know what you do and find up
