Chevy starter question
#3228009
04/19/24 06:20 AM
04/19/24 06:20 AM
Posts: 5,647 Port Huron, Michigan
MI_Custumz
I have a small block in my 70 Monte. Ever since I bought it 18 years ago, the starter needed to be given a jolt of juice once in a while. The previous owner had a jumper wire from the fuse block to the starter solenoid with a switch under the steering column to give it juice when needed. It has a good battery, starter doesn't make any funny noises, but sometimes it's just nothing at all (no click, grinding, nothing). I have replaced the battery cables and have tested the voltage at the battery and the starter end of it, both about the same. I think I tested it with the key on as if it was starting when I had the starter out last time to replace cables and it was real close there too. Do the solenoids go bad and if so, are they replaceable without replacing the entire starter? I know I could go with a new starter or mini one, but I was thinking maybe the solenoid may have an internal issue with the flow of power since it starts every time I hit the switch on the inside of the car. I'll have to admit, it is nice to have it not start with the key alone sometimes. It's like an anti theft device, but would like to see if I can fix it easily.
Re: Chevy starter qeustion
[Re: MI_Custumz]
#3228015
04/19/24 08:06 AM
04/19/24 08:06 AM
Posts: 5,812 ohio
ruderunner
ohio
Number 1 issue is undersized wiring leading to low voltage causing slow or no crank.
But, if you get nothing, neutral switch or ignition switch are suspected. They could be worn or in need of adjustment.
Angry white pureblood male
[Re: ruderunner]
#3228032
04/19/24 10:40 AM
04/19/24 10:40 AM
Posts: 6,240 nowhere
Sniper
nowhere
You can jumper around both the neutral safety switch and ignition switch to eliminate them as the problem. However, since this appears to be an intermittent issue, that may not resolve anything during testing. Maybe next time it is acting up you can do the jumpering and see what changes..
Yes, solenoids can go bad.
Yes, they can be replaced.
However, it might be time to just up and buy a nice, shiny all new one and stop farting about with something that is old. Unless it's some sort of all original car that is and if it is rebuilding your old solenoid might be an idea to consider. No kits that I know of to do that, however, it can be done.
Well, dang, they do make a rebuild kit for your solenoid, assuming it is the original starter. Rock Auto has them. I;m used to old flathead mopars and no one makes kits for those. You have to hand wind your own, lol.
[Re: Sniper]
#3228050
04/19/24 11:20 AM
04/19/24 11:20 AM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
What used to be, and what currently is may be completely different these days, but you used to be able to replace the solenoid on the old GM starters. You have to remove the starter from the car to replace the solenoid. That said, I have to wonder if since someone ran a wire down to the starter, if the problem lays elsewhere (unless the starter is a royal pain to change). I'm betting the extra wire you spoke of bypasses everything between the battery and the starter. Someone didn't know how to chase down the problem, or couldn't find the problem, so they just added the extra wire. It is possible that simply replacing the extra wire with another will make it work "like it always has".
Personally, if it was mine, I'd replace the starter as a starting point, if its still the original, its spent a lot of time just sitting, or it could be completely wore out. You will have to pull it out to do just about anything with it, I probably would not put that old starter back in without a complete rebuild unless you know its full history. We have places in our town that actually rebuild the old starters and alternators, might be better then the new Chiniseum stuff on the market these days.
[Re: poorboy]
#3228070
04/19/24 12:10 PM
04/19/24 12:10 PM
Posts: 1,821 South Bend
John Brown
South Bend
Number one problem when a GM starter just clicks and doesn't turn over is the solenoid. Number two problem when that happens is bad brushes. If you can rap the starter with a hammer and it cranks over, suspect it needs brushes. A jumper wire will cover up a lot of sins by delivering more voltage which just covers up the problem, but doesn't solve it. Either way, I'd rebuild the original starter if you want reliabilty, since many parts store rebuilds are carp. Another solution is replacing the old starter with a brand new super small PMGR starter. There are many later model cars that use them and older cars can be retrofitted, especially if the car or truck in question has a HEI distributor. The PMGR starters usually require different starter specific bolts, due to the starter having metric size mounting holes and the block having US spec threads. Some starters come with the needed bolts, some don't. Number of teeth on flywheel/flexplate determines whether a straight across or angled bolt pattern is used. Here's a PDF on Remy starters that can be interchanged. Linky --> PMGR Remy Chevrolet starter info.A 1970 Monte Carlo came with points, and a PMGR starter that has the "R" terminal would be needed. If the distributor has been replaced with an HEI, the "R" terminal on the starter is not needed.
[Re: poorboy]
#3228126
04/19/24 05:00 PM
04/19/24 05:00 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
If it works everytime with the bypass wire, I would say you have a switch or wiring issue. GM's typically use a purple wire form the Ign. switch directly to the solenoid to energize it. When the solenoid energizes it pulls a shorting contact forward that send battery power to the starter motor and on PRE HEI cars battery power to the coil bypassing the points resistance wire for starting. It also sends the Starter Bendix back to the flywheel engaging the teeth before the SM starts turning. Energizing the solenoid is audibly noticeable. So while it is possible the solenoid is at fault, I would suspect the switch or wiring first.
[Re: MI_Custumz]
#3228355
04/20/24 11:22 PM
04/20/24 11:22 PM
TJP
Omaha Ne
I just seem to think the worse in things. Hoping if I need a new starter, that it won't need shimmed. If it does, I'll take it slow and easy and ask questions (sometimes hard for me to do) for answers. I have tried it in neutral and jiggled the handle. None of that seems to make a difference. I'll jiggle it tonight if it won't start. Daughter wants to take senior prom pictures with it. Don't want to tear anything apart tonight. She would be very upset. A trick we have done in the past is to swap the starter end to the replacement unit which maintains the original engagement with the flywheel. If so inclined to verify the solenoid is the issue, one could easily run a temporary wire from the start terminal to a small light inside the car. this would Verify if the Voltage is getting to the terminal or not . if not you know your problem is elsewhere
[Re: MI_Custumz]
#3228512
04/21/24 10:54 PM
04/21/24 10:54 PM
TJP
Omaha Ne
do be aware that current and V are two different things. So you may have enough of both for a light bulb, but Not enough Current for the solenoid. This is Why I suggested a wire off the Start terminal to a bulb inside the car. If you have a flakey connection that is not passing enough current for the solenoid the bulb will be very dim or not light at all. Hope this makes sense keep us posted
[Re: TJP]
#3228546
04/22/24 06:54 AM
04/22/24 06:54 AM
MI_Custumz
do be aware that current and V are two different things. So you may have enough of both for a light bulb, but Not enough Current for the solenoid. This is Why I suggested a wire off the Start terminal to a bulb inside the car. If you have a flakey connection that is not passing enough current for the solenoid the bulb will be very dim or not light at all. Hope this makes sense keep us posted I pulled the cover off the console to get to the NSS. I only got a few things tested because I had other things I had to get done around the house. I had a test light that lit up pretty good for power to the one purple wire, so safe to say that's the power from the ignition and the other purple is going to the solenoid. I got 11.96V when the key was in the start position. My next steps will be to put the wires back on and hopefully it won't start so I can check the other purple wire in the console. I will also check the reverse lights for power and voltage just like the ignition one to make sure they are the same since the reverse lights work. Should tell me if the start portion is bad I'm hoping. If It doesn't start, I'll use the jumper wire to bypass the switch. If the NSS needs replaced, is there any alignment issues I need to look at like the ignition switch on the column? I know I probably don't need to check the reverse lights since they work, but I like to know how things work. I'm thinking key on and shifter in reverse should turn on the reverse lights. It should also light them up in any position if I jump those together as well right? Same concept as the ignition wire. If the ignition wire is bad to the starter, I'm hoping to connect a wire to the purple and just pull it through to the starter. Will have to take the wire off the starter to test it as well, but just thinking out loud.
[Re: MI_Custumz]
#3228640
04/22/24 07:23 PM
04/22/24 07:23 PM
MI_Custumz
Went out to tinker with it again today. I used a pair of thin pliers to jump the reverse light wires while they were off the neutral safety switch. I wasn't a fan of trying to hold onto a wire just in case. That worked like it should, so I knew the method would work for bypassing the NSS to start it. I used the multi meter to check continuity on the reverse and ignition tabs. All is well there as far as I can tell, the multi meter beeped. I put the ignition wires back on the NSS and tried to start it. Nothing, but I was glad that way I could try to test the other wire for power after the switch since I already knew the power was good going to the switch. The test light lit up, but couldn't get a multi meter reading. Too tight of a space. I put in a thin wire in the back of the connections and used the test light to see if it would read. Yup, lit the light up and got a voltage reading. The reading was real close on both connections. It still wouldn't start. I removed the connector and tried jumping it with pliers like the reverse connectors. Nothing. I used the button from the fuse panel power, and it fired up. I am not sure where the wire from the NSS to the solenoid goes, but the next step is to see if it has any power or voltage at the starter. Going to put it on jack stands so I don't have to start it and check more stuff when I get a chance. I was going to remove the wires from the solenoid and see if the ignition one has power and voltage and test the fuse box one. That should tell me if it's the ignition wire from the NSS to the solenoid I hope. I am also hoping it won't start and I can test light the wire on the solenoid. Keep the ideas coming as I appreciate all the help and enjoy tinkering with it, even if I do get frustrated a bit here and there.
[Re: MI_Custumz]
#3228678
04/22/24 11:23 PM
04/22/24 11:23 PM
TJP
Omaha Ne
Went out to tinker with it again today. I used a pair of thin pliers to jump the reverse light wires while they were off the neutral safety switch. I wasn't a fan of trying to hold onto a wire just in case. That worked like it should, so I knew the method would work for bypassing the NSS to start it. I used the multi meter to check continuity on the reverse and ignition tabs. All is well there as far as I can tell, the multi meter beeped. I put the ignition wires back on the NSS and tried to start it. Nothing, but I was glad that way I could try to test the other wire for power after the switch since I already knew the power was good going to the switch. The test light lit up, but couldn't get a multi meter reading. Too tight of a space. I put in a thin wire in the back of the connections and used the test light to see if it would read. Yup, lit the light up and got a voltage reading. The reading was real close on both connections. It still wouldn't start. I removed the connector and tried jumping it with pliers like the reverse connectors. Nothing. I used the button from the fuse panel power, and it fired up. I am not sure where the wire from the NSS to the solenoid goes, but the next step is to see if it has any power or voltage at the starter. Going to put it on jack stands so I don't have to start it and check more stuff when I get a chance. I was going to remove the wires from the solenoid and see if the ignition one has power and voltage and test the fuse box one. That should tell me if it's the ignition wire from the NSS to the solenoid I hope. I am also hoping it won't start and I can test light the wire on the solenoid. Keep the ideas coming as I appreciate all the help and enjoy tinkering with it, even if I do get frustrated a bit here and there. keep in mind, if you disconnect the purple wire at the starter, You may have voltage with little or no load The test light on the Start terminal will expose whether the CURRENT is there along with the Voltage
[Re: MI_Custumz]
#3228692
04/23/24 02:15 AM
04/23/24 02:15 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Where is this car driven? If east of the Rockies Mtns. does it have rusted floors and frames? If so check all the grounds to make sure their really good , most people don't know that all the current coming out of any and all batteries comes out the negative side and then flows through the circuit back o the positive lead to the battery, not vice a versa like most people think Good luck, let us know what you do and find
