Power booster for 66 Plymouth Fury C-Body #3227640
04/17/24 10:00 AM
04/17/24 10:00 AM
Omaha
Tracy Willits Offline OP
Omaha
Anyone found a source for these? I'm wondering if I can use the newer style meant for front disc brakes? All help appreciated. Thanks, Tracy.
Re: Power booster for 66 Plymouth Fury C-Body [Re: Tracy Willits] #3227643
04/17/24 10:05 AM
04/17/24 10:05 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
You have a '66 power disc brake car?
Re: Power booster for 66 Plymouth Fury C-Body [Re: 6PakBee] #3227661
04/17/24 11:11 AM
04/17/24 11:11 AM
Omaha
Omaha
No-4 wheel drums with power. My question is can I use a later power booster/master cylinder combo from a later mopar with power brakes. I may have to get a kit to convert mine to front power discs if I can't find a power booster for mine. My power booster takes the old style master cylinder with 4 bolts attaching verses the newer style with a 2 bolt on master cylinder. As far as I can tell noboby makes the correct power booster anymore. I was looking at replacing mine with a newer style from the late 60s/early 70s that may match up to the firewall. The combo is from Leed Brakes and says that I may have to either adapt the new set to the firewall or make a new plate. I can do either. Just curious if anyone else has done that or converted to front discs.
Re: Power booster for 66 Plymouth Fury C-Body [Re: Tracy Willits] #3227669
04/17/24 11:28 AM
04/17/24 11:28 AM
North Dakota
North Dakota
I am confident these guys can rebuild your existing booster.
Power Brake Booster Exchange
Re: Power booster for 66 Plymouth Fury C-Body [Re: 6PakBee] #3227703
04/17/24 01:33 PM
04/17/24 01:33 PM
Omaha
Omaha
Thanks 6pak. I never knew they even existed. I was looking for the parts to rebuild it myself as 25 years ago I was a Chrysler master mechanic-i rebuilt engines, tranny, and drivelines at a local dealership . Got laid off when they went to only factory rebuilds. I will call them.
Re: Power booster for 66 Plymouth Fury C-Body [Re: Tracy Willits] #3227705
04/17/24 01:37 PM
04/17/24 01:37 PM
Omaha
Omaha
Called and they said they could definitely do it. I am going to get it off and sent in today. Thanks again 6pak!
Re: Power booster for 66 Plymouth Fury C-Body [Re: Tracy Willits] #3227781
04/17/24 09:25 PM
04/17/24 09:25 PM
North Dakota
North Dakota
That's what we're all here for, to try to help each other out.
