Re: 727 torqueflite high psi relief
[Re: TrackPack]
#3227079
04/14/24 06:07 PM
04/14/24 06:07 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The relief ball didn't arrive until late '68.
The '66 VB had some issues , look for a crack shown in the pic below and, if you intend to do many manual 1-2 upshifts, an orifice restrictor shown by the red arrow needs to be drilled out to at least 1/8".
[Re: TrackPack]
#3227179
04/15/24 12:30 PM
04/15/24 12:30 PM
Posts: 19,438 north of coder
moparx
one can use a spare chuck and turn it with your hand, going up a couple drill sizes at a time, or use a cordless drill at a somewhat slow speed, [also a couple sizes at a time.] lightly clamp the valve body in a vice, using two pieces of unmolested plywood [without dirt, metal chips, etc embedded in them] covered with two pieces of clean cardboard, will hold it at an angle that is comfortable for you to drill. just be sure you don't use anything in the clamping process that will mark up the valve body.
[Re: TrackPack]
#3227184
04/15/24 12:40 PM
04/15/24 12:40 PM
John_Kunkel
Rio Linda, CA
Thanks for the reply!
Any advice on drilling out the restictor? Looks like any drilling will have to be done at an angle? I drill it at the original angle with a 1/8" bit then, when the bit goes through to the channel, I walk the bit up vertical to remove the remaining partition.
[Re: John_Kunkel]
#3227897
04/18/24 01:26 PM
04/18/24 01:26 PM
Posts: 75,037 U.S.S.A.
JohnRR
U.S.S.A.
The '66 VB had some issues , look for a crack shown in the pic below and, if you intend to do many manual 1-2 upshifts, an orifice restrictor shown by the red arrow needs to be drilled out to at least 1/8". John , what causes the valvebody to crack there ?
[Re: JohnRR]
#3227901
04/18/24 01:59 PM
04/18/24 01:59 PM
John_Kunkel
Rio Linda, CA
The '66 VB had some issues , look for a crack shown in the pic below and, if you intend to do many manual 1-2 upshifts, an orifice restrictor shown by the red arrow needs to be drilled out to at least 1/8". John , what causes the valvebody to crack there ? I dunno, I've seen at least two crack in the same place.
[Re: John_Kunkel]
#3227916
04/18/24 03:23 PM
04/18/24 03:23 PM
JohnRR
U.S.S.A.
The '66 VB had some issues , look for a crack shown in the pic below and, if you intend to do many manual 1-2 upshifts, an orifice restrictor shown by the red arrow needs to be drilled out to at least 1/8". John , what causes the valvebody to crack there ? I dunno, I've seen at least two crack in the same place. Ok thanks , I'll be sure to look at that location if I'm into one that old.
