Question about heat treating #3226891
04/13/24 02:41 PM
04/13/24 02:41 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have a part (it's a gear) and I'm uncertain if it is heat treated.
Since I don't know, is there any harm in having it heat treated ?
If it is NOT previously heat treated, then I'm safe.
If it IS in fact already heat treated, then it would be " doubly" heat treated. Is this bad ? Is this even a concern ?
See my question ?
Re: Question about heat treating [Re: hemienvy] #3226895
04/13/24 03:08 PM
04/13/24 03:08 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Maybe
No
Probably not
But the guy at the heat treat place can answer all of that. It will be a lot easier for him because it will be in his hand.
2011 Drag Pak Challenger
Re: Question about heat treating [Re: hemienvy] #3226899
04/13/24 03:43 PM
04/13/24 03:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Gears are usually case hardened, a heat treat facility will have a hardness tester and can advise you. A simple "file test" will usually identify a case-hardened part...if an ordinary file will remove material from the gear, it's not case hardened.
Re: Question about heat treating [Re: hemienvy] #3226965
04/14/24 12:12 AM
04/14/24 12:12 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
dependes also on what you want to gain
how about cyrogenic treatment.
i am currently waiting on a trsns i sent out to be treated cyrogenic
Re: Question about heat treating [Re: calrobb2000] #3226983
04/14/24 09:55 AM
04/14/24 09:55 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by calrobb2000
hi
Who did you have do the work? I have a T-10 that I'm seriously considering doing this to the gearing.
Re: Question about heat treating [Re: 6PakBee] #3227007
04/14/24 12:34 PM
04/14/24 12:34 PM
moparx Offline
moparx  Offline
sometimes, re-heat treating a part will ruin it.
at work we heat treated a few parts we made in house, and if not done correctly, trying to redo them usually ended up causing the parts to be scrapped because they became very brittle.
as i was not personally involved in the heat treat process, other than machining the parts, i don't know if it was the process used, the guy doing it, or other factors.
just my [very limited] personal experience. your mileage will vary.
beer
Re: Question about heat treating [Re: moparx] #3227041
04/14/24 02:40 PM
04/14/24 02:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The shop doing thew heat treating should be able to guide you what needs to be done if anything.
Re: Question about heat treating [Re: hemienvy] #3227057
04/14/24 04:31 PM
04/14/24 04:31 PM
E
earlymopar Offline
earlymopar  Offline
E
What John said WRT to case hardening (carburizing) is most often correct. However, you really need to know what steel grade you have if it needs further heat treatment.
Re: Question about heat treating [Re: earlymopar] #3227073
04/14/24 05:47 PM
04/14/24 05:47 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK, I took a file to the gear, fairly sharp file. It kind of "marred" the gear surface, maybe took off a VERY slight amount
of surface metal, but I was using pretty light pressure.
But it's definitely harder than angle iron.
Re: Question about heat treating [Re: 6PakBee] #3227128
04/15/24 12:18 AM
04/15/24 12:18 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
should be able to get it done in any decent size city near you .
i found a guy in york pa , 15 miles from me . 717 309 0639
search the net for cyrogenic treatment near you !
Re: Question about heat treating [Re: calrobb2000] #3227158
04/15/24 09:38 AM
04/15/24 09:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
hi
Thanks for the info. I'm in ND, there is no "decent size city" near me. (of course I guess it depends on what you consider "near", definitely not 15 miles away) grin
Re: Question about heat treating [Re: hemienvy] #3227180
04/15/24 12:30 PM
04/15/24 12:30 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
A thorough answerer can be better provided with more info. What type of gear is it, what's it indented use etc.?
Heat treating is not "Just" hardening of metal. I suggest you read this HEAT TREATMENT
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
