Re: Question about heat treating
[Re: hemienvy]
#3226895
04/13/24 03:08 PM
04/13/24 03:08 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Maybe No Probably not But the guy at the heat treat place can answer all of that. It will be a lot easier for him because it will be in his hand.
2011 Drag Pak Challenger
[Re: hemienvy]
#3226899
04/13/24 03:43 PM
04/13/24 03:43 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Gears are usually case hardened, a heat treat facility will have a hardness tester and can advise you. A simple "file test" will usually identify a case-hardened part...if an ordinary file will remove material from the gear, it's not case hardened.
[Re: calrobb2000]
#3226983
04/14/24 09:55 AM
04/14/24 09:55 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
,, hi dependes also on what you want to gain
how about cyrogenic treatment.
i am currently waiting on a trsns i sent out to be treated cyrogenic Who did you have do the work? I have a T-10 that I'm seriously considering doing this to the gearing.
[Re: 6PakBee]
#3227007
04/14/24 12:34 PM
04/14/24 12:34 PM
Posts: 19,405 north of coder
moparx
sometimes, re-heat treating a part will ruin it. at work we heat treated a few parts we made in house, and if not done correctly, trying to redo them usually ended up causing the parts to be scrapped because they became very brittle. as i was not personally involved in the heat treat process, other than machining the parts, i don't know if it was the process used, the guy doing it, or other factors. just my [very limited] personal experience. your mileage will vary.
[Re: moparx]
#3227041
04/14/24 02:40 PM
04/14/24 02:40 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
The shop doing thew heat treating should be able to guide you what needs to be done if anything.
[Re: calrobb2000]
#3227158
04/15/24 09:38 AM
04/15/24 09:38 AM
6PakBee
North Dakota
hi should be able to get it done in any decent size city near you .
i found a guy in york pa , 15 miles from me . 717 309 0639
search the net for cyrogenic treatment near you !
Thanks for the info. I'm in ND, there is no "decent size city" near me. (of course I guess it depends on what you consider "near", definitely not 15 miles away)
[Re: hemienvy]
#3227180
04/15/24 12:30 PM
04/15/24 12:30 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
A thorough answerer can be better provided with more info. What type of gear is it, what's it indented use etc.? Heat treating is not "Just" hardening of metal. I suggest you read this HEAT TREATMENT
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
