Strange S60 bearing options 2.875 vs 3.150 #3225592
04/07/24 12:24 PM
04/07/24 12:24 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
I am planning to order an S60 to replace the poorly cut down dana 60 in my Cuda installed by the previous owner, and at the same time move the springs back out to the standard location so that the shackles don't constantly hit the rear valance. mad
Filling out the Strange data sheet I noticed that they offer a mopar style housing end that will fit a 'large ford' style 3.150" OD bearing, or the housing for the standard size bearing.
Any reason I should not order the larger bearing? Nothing on the car is original anyway so cutting the brake backing plates to clear the larger bearing does not concern me.
I 'assume' that the extra .275 diameter allows for more & larger diameter ball bearings, and should provide a pretty significant increase in strength?
Comments?
Street car with 275 Nittos, 3.54 ratio & Eaton Truetrac, TKX 5 speed & bmp hemi.
Craig
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3225623
04/07/24 01:12 PM
04/07/24 01:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you going to run green type bearings or use the stock tapered bearing ?
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: JohnRR] #3225628
04/07/24 01:37 PM
04/07/24 01:37 PM
Craig J Offline OP
Craig J  Offline OP
Ball bearing, I am not sure if it is mfg by Green.
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3225657
04/07/24 04:56 PM
04/07/24 04:56 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The only other issue might be the bearing retainer bolts might not line up with the housing ends. Does it come with retainers? I don't know why you would need the larger bearing. 40 spline upgrade maybe shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: fourgearsavoy] #3225676
04/07/24 07:47 PM
04/07/24 07:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you are reusing your current brakes? The parts won't bolt on with different bolt pattren ends.
Doug
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3225689
04/07/24 09:31 PM
04/07/24 09:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Green is a generic term at this point , just run the stock mopar bearing size , as other said , your factory brakes aren't going to fit , if you are going aftermarket rear disc then you have a better chance of getting something like TBM because they don't make parts for the musclecar era mopars that I have been able to find
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3225696
04/07/24 10:08 PM
04/07/24 10:08 PM
AndyF Online content
AndyF  Online Content
The Torino ends are really nice since they use a big bearing and they are sealed up pretty well but stock drum brakes are not going to bolt on and you might not be able to modify the backing plate to work with the larger housing. I suggest shooting an email to DoctorDiff and seeing what he says. He has more knowledge in this area than most folks.
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: AndyF] #3225711
04/08/24 12:03 AM
04/08/24 12:03 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I got the larger bearing ends, Dr Diff said to carefully enlarge the hole in my stock backing plates, works great, lots of miles on it
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3225734
04/08/24 08:44 AM
04/08/24 08:44 AM
an8sec70cuda Offline
You don't need the big ford ends/bearings unless you're going w/ 40 spline axles.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3225789
04/08/24 12:49 PM
04/08/24 12:49 PM
If you want to use a decent posi unit with 35 spline axles instead of the larger 40 spline race axles and spool I would order the 35 spline axle package work up twocents
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Cab_Burge] #3225791
04/08/24 12:51 PM
04/08/24 12:51 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
That's what I went with. It uses a big ford bearing but still uses the Mopar bolt pattern so brakes were a direct bolt on.
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: INTMD8] #3225792
04/08/24 12:55 PM
04/08/24 12:55 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: INTMD8] #3225815
04/08/24 02:00 PM
04/08/24 02:00 PM
Yeah that will work when you use the matching H1147 Mopar housing ends.
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: AndyF] #3225848
04/08/24 04:12 PM
04/08/24 04:12 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes I thought those were the ones he was asking about.
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: dvw] #3225859
04/08/24 05:41 PM
04/08/24 05:41 PM
Craig J Offline OP
Craig J  Offline OP
Doug
It seems like Strange made the effort to make the bigger bearing work with the mopar brakes.
Re: Strange S60 bearing options 2.875 vs 3.150 [Re: Craig J] #3226008
04/09/24 11:47 AM
04/09/24 11:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doug
Did not know that , seems like a no brainer then to go with the bigger bearing
