Re: PCV, EVAC or PUMP
[Re: 4mopower]
#3224742
04/03/24 01:27 PM
04/03/24 01:27 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I would also like to know, I’m curious if anyone has tried using an OEM vacuum pump a lot of the European cars have? I use a PCV valve on one valve cover and a breather on the other. Definitely use a catch can
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: 4mopower]
#3224756
04/03/24 02:20 PM
04/03/24 02:20 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
At what point did you step up on a street driven BB. Is Evac usable on the street? would you use a oil catch with the Evac? Breather on one cover and evac on the opposite side? Or two evac's? I run an evac on my race/street stroker. It pulls 5 inches at idle. Two breathers, one on each side in valve covers. Been like this for at least twenty years with no issues. I would guess that a lot would depend on the cam specs. What I have works for my set up very well.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 4mopower]
#3224768
04/03/24 02:38 PM
04/03/24 02:38 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I run a GZ vacuum pump on the street. Works great, I'm happy with it.
[Re: INTMD8]
#3224890
04/03/24 10:01 PM
04/03/24 10:01 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I run a Moroso advanced 4 vane for street/strip use works great also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 4mopower]
#3225667
04/07/24 07:04 PM
04/07/24 07:04 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I was recently thinking about the evac setup bc I am pushing oil out breathers at higher rpm. However, trying to figure out how Not to kill my o2 sensors in the collectors. So, I put it off for now. Just another thought if you run o2 sensors.
[Re: 68LAR]
#3225675
04/07/24 07:43 PM
04/07/24 07:43 PM
Posts: 9,839 MI, usa
dvw
MI, usa
At what point did you step up on a street driven BB. Is Evac usable on the street? would you use a oil catch with the Evac? Breather on one cover and evac on the opposite side? Or two evac's? I run an evac on my race/street stroker. It pulls 5 inches at idle. Two breathers, one on each side in valve covers. Been like this for at least twenty years with no issues. I would guess that a lot would depend on the cam specs. What I have works for my set up very well. How do you get 5"hg at idle with breathers? Doug
[Re: dvw]
#3225697
04/07/24 10:16 PM
04/07/24 10:16 PM
Posts: 16,481 On the run…
BloFish
On the run…
My simple set up.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Chargerfan68]
#3225715
04/08/24 06:19 AM
04/08/24 06:19 AM
Posts: 162 Chicago-area Illinois
4mopower
Chargerfan68 - I am running O2 sensors but I was thinking of moving the check valve downstream of the collector.
[Re: dvw]
#3225721
04/08/24 07:25 AM
04/08/24 07:25 AM
68LAR
South Park, Pa.
At what point did you step up on a street driven BB. Is Evac usable on the street? would you use a oil catch with the Evac? Breather on one cover and evac on the opposite side? Or two evac's? I run an evac on my race/street stroker. It pulls 5 inches at idle. Two breathers, one on each side in valve covers. Been like this for at least twenty years with no issues. I would guess that a lot would depend on the cam specs. What I have works for my set up very well. How do you get 5"hg at idle with breathers? Doug I don’t know to be truthful. I installed the evacuation system and checked it with a vacuum gauge and this is what I got. I do know that on the street, you need straight thru mufflers. Chambered mufflers have too much back pressure. Maybe this is why it works for me. I run Magnaflows.
[Re: 68LAR]
#3225733
04/08/24 08:42 AM
04/08/24 08:42 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
For a mostly street car, I like two big hoses (-10). One on each valve cover to a breather tank. No pcv or pump.
