How many passes 'til your drag radials start to go away? #3225034
04/04/24 02:21 PM
04/04/24 02:21 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I'm just full of questions today
My ET Street S/S are a couple years old and coming up on 50 passes. Seems to me like they're starting to slow down in the 60 by a few hundredths... from maybe 1.68-1.70 to 1.74-1.76, even though they're still showing "legal" tread depth left for street use. Does this sound about right to others who drive on the same tires to the track as they race on? I suppose this could be the effect of repeated heat cycling from street & track usage.
Also, anyone have direct 60 ft / ET comparisons between ET Street S/S and ET Street R of comparable sizes? My S/S are 305/40R18 (28" tall), but I have a set of ET Street R 305/45R18 (29" tall, probably a tad lighter) on hand, too. Wondering if I should expect they'll perform the same, or if the "R" might be a tad quicker. Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How many passes 'til your drag radials start to go away? [Re: Brad_Haak] #3225063
04/04/24 04:45 PM
04/04/24 04:45 PM
an8sec70cuda Offline
I usually get around 50 passes out of my 295-65 ET Street radials.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How many passes 'til your drag radials start to go away? [Re: an8sec70cuda] #3225156
04/05/24 06:55 AM
04/05/24 06:55 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Maybe too much burnout? We run the 275-60-15 ET Street Pro and they seem to get BETTER the more they are used. I have seen them work with no tread at all left. Maybe compound differences. This is with double beadlock wheels and 12" rims.
Re: How many passes 'til your drag radials start to go away? [Re: fbs63] #3225196
04/05/24 11:09 AM
04/05/24 11:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think my 275 pros are good for around 100 passes depending on how much I street drive them. They never seem to fade as far as ET goes but they run out of grooves.
68 Barracuda Formula S 340
Re: How many passes 'til your drag radials start to go away? [Re: Bad340fish] #3225217
04/05/24 12:28 PM
04/05/24 12:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Drag Radials only need enough heat to start smoking. Anything more is just wasting tire. We have run them until cords are about showing. Or, until they look like slicks any way. Still almost work just as good as new.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: How many passes 'til your drag radials start to go away? [Re: 6PKRTSE] #3225231
04/05/24 01:30 PM
04/05/24 01:30 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Does anybody swap tires side to side anymore when they quit biteing? We sure used to.
Re: How many passes 'til your drag radials start to go away? [Re: John Brown] #3225240
04/05/24 02:13 PM
04/05/24 02:13 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Most radial race tyres are directional, at least the ones I've used are. With the Radial Slicks we use I can go past the wear-markers after about 50 passes, they still work just as well. OH, and I don't do a big burnout either.
Re: How many passes 'til your drag radials start to go away? [Re: Tig] #3225246
04/05/24 02:45 PM
04/05/24 02:45 PM
Loudoun County, VA
Loudoun County, VA
I may be putting too much heat into them... but I also know what's happened when I've messed up and not put enough
FWIW, I estimated I've got about 1K of street-driven miles on these tires, mostly going to and from the tracks.
Re: How many passes 'til your drag radials start to go away? [Re: Brad_Haak] #3225272
04/05/24 05:58 PM
04/05/24 05:58 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mine take a very short burnout to get sticky.
I've ran 1.36 60 ft. just before the two grooves were gone on a set of 275 ET Street Pros.
Lots of passes and extended life if you treat them right. I'm on my 3rd pair in 10 seasons.
'63 Dodge 330
11.19 @ 121 mph
Re: How many passes 'til your drag radials start to go away? [Re: GY3] #3225307
04/05/24 09:47 PM
04/05/24 09:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Just driving on the street while my brother was following me in another one of my cars, I switched lanes to get over and my drag radial peeled the white line right off the road. When he told me when we arrived at the cruise night, I checked my rear tire and portions of the white line was still stuck to the tire. They get sticky even without a burnout.
Re: How many passes 'til your drag radials start to go away? [Re: 6PKRTSE] #3225357
04/06/24 08:42 AM
04/06/24 08:42 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I know MT recomends the ET Street SS for more street than track. Vice versa with the ET Street R. The R tire uses the same compound as the Pro Bracket Radial so it is better for marginal prep.
Re: How many passes 'til your drag radials start to go away? [Re: fbs63] #3225390
04/06/24 11:13 AM
04/06/24 11:13 AM
Loudoun County, VA
Loudoun County, VA
That's why I bought Rs to replace the S/S since I swap 'em out for normal street use anyway.
I didn't realize my S/S had that much tread left (at least 3/32) until I pulled 'em off the last time, so I'd rather get my money's worth if they're not losing grip. I'll see if shorter burnouts make any difference, too.
