Any reason to switch to wrap-around style harness?
#3224978
04/04/24 11:22 AM
04/04/24 11:22 AM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
My new 5-point harness expired before I could install it. My Challenger still uses the OEM seats and has a single tab on the rollbar for the shoulder straps to bolt to behind the seat. The same style harness is also available as a wrap-around style for the shoulder straps. Is there any reason why I'd want to switch from what I have now to the wrap-around design? There's basically no price difference. Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Any reason to switch to wrap-around style harness?
[Re: Brad_Haak]
#3224991
04/04/24 12:16 PM
04/04/24 12:16 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3225010
04/04/24 12:54 PM
04/04/24 12:54 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
The only argument that could be made with a single anchor point it that is all that used to keep them from moving is that welded tab and bolt...I have run both and have both in my two cars currently.
[Re: Al_Alguire]
#3225022
04/04/24 01:52 PM
04/04/24 01:52 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
The only argument that could be made with a single anchor point it that is all that used to keep them from moving is that welded tab and bolt.. Think of it this way...Would you rather pick up on the edge of a 3/16" thick wheelbarrow handle or a 1.625" round handle? That is what you belt straps are doing. I use wrap around.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Brad_Haak]
#3225025
04/04/24 02:05 PM
04/04/24 02:05 PM
Posts: 2,919 A shed in England
Tig
A shed in England
Over here in the UK 5 point harnesses are no longer legal, you can't actually buy a tagged 5 point anymore. Moved over to six point and the scrutineers all recommend wrap around.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3225037
04/04/24 02:24 PM
04/04/24 02:24 PM
Brad_Haak
Loudoun County, VA
Thinking at the moment about going w/ wrap-around and picking up some roll bar collars / clamps to keep 'em from moving apart too far under tension
[Re: Brad_Haak]
#3225120
04/04/24 09:59 PM
04/04/24 09:59 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I prefer wrap arounds with a retainer welded to the tube.
[Re: CMcAllister]
#3225222
04/05/24 12:44 PM
04/05/24 12:44 PM
Al_Alguire
Las Vegas
You made me look as I am old. Both of my racecars are wrap around the streetcar is a bolt in but uses two anchor points. But Ill admit those belts are OLD.
