A lot of work for 650 hp #3223726
03/30/24 02:46 PM
03/30/24 02:46 PM
AndyF Online content OP
AndyF  Online Content OP
Saw this article on Hot Rod today. All aluminum Pontiac with lots of good parts including dry sump and very fancy headers, Cam is fairly small and the header shape is unusual so I'm guessing that this is a street engine in some sort of weird vehicle? The article doesn't say what it is going into but the cam is too small for drag racing. I suppose it could be some sort of road race car. The small cam, dry sump and weird headers could all work in a road race vehicle.
https://www.motortrend.com/how-to/510-inch-pump-gas-pontiac-engine-westech-dyno-test/
Re: A lot of work for 650 hp [Re: AndyF] #3223740
03/30/24 03:31 PM
03/30/24 03:31 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Road racing wouldn't you want quick revving and top end rpm vs just big cubic inches? Seems like a very expensive way to get there as well? Buicks, Olds, and Pontiacs cost $$$ to build.
I look at engines like that with all the trick do-dads and then look at how fast the F.A.S.T. class guys run with no real visible speed parts and it makes me wonder how much of the trick looking stuff does one really need?
Re: A lot of work for 650 hp [Re: Neil] #3223742
03/30/24 03:51 PM
03/30/24 03:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It says torque wins races. Of course that's not true. If it was, we'd all have semi truck engines in our race cars. Horsepower to weight ratio wins races.
And I agree, the Pontiac motor has way too much in to it to only make 650 horse.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: A lot of work for 650 hp [Re: Hemi_Joel] #3223746
03/30/24 04:06 PM
03/30/24 04:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Switch the carb and it will pick up power...
Re: A lot of work for 650 hp [Re: Hemi_Joel] #3223747
03/30/24 04:09 PM
03/30/24 04:09 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Agree, looks pretty exotic build for those kind of numbers. That engine is far less than the sum of its' parts. Wonder if the cam is mistimed, either installed wrong or ground wrong.
Re: A lot of work for 650 hp [Re: Hemi_Joel] #3223757
03/30/24 04:44 PM
03/30/24 04:44 PM
Minn
SportF Offline
SportF  Offline
Minn
Wow, exactly right on the horsepower! I snicker every time I hear the torque statement.
Re: A lot of work for 650 hp [Re: Hemi_Joel] #3223778
03/30/24 07:28 PM
03/30/24 07:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thank you!!
Re: A lot of work for 650 hp [Re: Al_Alguire] #3223780
03/30/24 07:31 PM
03/30/24 07:31 PM
Yeah I have serious doubts about that carb design. I would be interested in the back story on the engine design. Peak power is 5900 RPM but the valvetrain and the oiling system appear to be NASCAR type stuff. 7/16 pushrods, Crower rocker arms. Peterson R4 pump, etc. Those are serious high dollar parts. Even the water pump uses a NASCAR style multigroove belt.
Maybe it is just designed to look like a NASCAR engine? Could be going into a vintage NASCAR chassis for track days or something.
Re: A lot of work for 650 hp [Re: AndyF] #3223789
03/30/24 08:29 PM
03/30/24 08:29 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Also has a Wilson bling spacer, real money was spent.
Re: A lot of work for 650 hp [Re: Uberpube] #3223844
03/30/24 10:03 PM
03/30/24 10:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What type of carb booster? are we looking at?
Doug
Re: A lot of work for 650 hp [Re: dvw] #3223872
03/30/24 11:52 PM
03/30/24 11:52 PM
PA
moparacer Offline
moparacer  Offline
PA
Doug
Booster? That looks like a derivative of Pro Systems old SV1 carb.
I mean, trying to reinvent the wheel sometimes doesn't work when the wheel was invented 5500 years ago. If something was better, it would have been figured out long ago.
Same with boosters. All this time with annular, dogleg, straight leg, forget all that....
Just drill some holes in a tube! laugh2
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: A lot of work for 650 hp [Re: moparacer] #3223975
03/31/24 12:26 PM
03/31/24 12:26 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Is this going in a boat?
Re: A lot of work for 650 hp [Re: A990] #3223977
03/31/24 12:30 PM
03/31/24 12:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
An "aerosol" carb. Design has been around for years and not very successful IMO and certsainly not the best way to make power.
Re: A lot of work for 650 hp [Re: AndyF] #3224019
03/31/24 02:47 PM
03/31/24 02:47 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Motor Trend and Westech Dyno are a platform to showcase advertisers' products. I remember Horsepower TV around 2012 Built an Edelbrock headed hydraulic roller cammed 440 six pack that made a whopping....410hp. Seems they want us to pay attention to the bling but not the power it makes.
Keep old mopars alive.
Re: A lot of work for 650 hp [Re: A990] #3224025
03/31/24 02:58 PM
03/31/24 02:58 PM
That is a really good possibility. Those headers could fit in a boat and that would explain the dry sump system as well as the heavy duty valve train. This engine design would make sense for a boat engine that was going to be pushed hard for long periods of time.
Re: A lot of work for 650 hp [Re: AndyF] #3224064
03/31/24 04:44 PM
03/31/24 04:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’ve dynoed motors with various versions of the KRE hi-ports.
One thing that seems a bit odd to me is the cam selection.
You’d think big split and wide lsa would have been used to help extend the power band, yet it’s peaking at only 5900.
Seems more like a street EFI type cam to me.
For sure, the hp doesn’t really seem commensurate with the total scope of the build……. At least in my mind.
Re: A lot of work for 650 hp [Re: fast68plymouth] #3224071
03/31/24 05:10 PM
03/31/24 05:10 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thats the same head I sent you for testing on your flow bench correct ???
Re: A lot of work for 650 hp [Re: BSB67] #3224109
03/31/24 08:40 PM
03/31/24 08:40 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Thank you!!
Thank you again.
Yes the cam is very strange. Good bit of lift but way short on duration (especially for the cubes) and wide lsa
Re: A lot of work for 650 hp [Re: INTMD8] #3224188
04/01/24 10:59 AM
04/01/24 10:59 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Probably for a heavy street car with 3.42 Gears and a very streetable converter. Definitely not a priority drag car.
with a 4.310 bore and 510 cubes I'm guessing its some kind of offset ground (2.200 BBC journal) factory Cast 455 crank.....So keeping the revs down and the torque up makes perfect sense to me.
So Because of that, I'm thinking the "small" intake lobe is the built-in Rev limiter for the combination. Thats a LOT of lift for that short of a
Pontiacs tend to like wider Lobe Separation angles and the cam in fairly late compared to a BB Mopar, I never understood exactly why,
WIZE
In Car:
Re: A lot of work for 650 hp [Re: Streetwize] #3224191
04/01/24 11:03 AM
04/01/24 11:03 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
That's got to be some killer ramp on the camshaft no?
