Re: A lot of work for 650 hp
[Re: Neil]
#3223742
03/30/24 03:51 PM
03/30/24 03:51 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
It says torque wins races. Of course that's not true. If it was, we'd all have semi truck engines in our race cars. Horsepower to weight ratio wins races.
And I agree, the Pontiac motor has way too much in to it to only make 650 horse.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3223746
03/30/24 04:06 PM
03/30/24 04:06 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Switch the carb and it will pick up power...
[Re: Hemi_Joel]
#3223757
03/30/24 04:44 PM
03/30/24 04:44 PM
Posts: 1,212 Minn
SportF
Minn
And I agree, the Pontiac motor has way too much in to it to only make 650 horse. Wow, exactly right on the horsepower! I snicker every time I hear the torque statement.
[Re: Hemi_Joel]
#3223778
03/30/24 07:28 PM
03/30/24 07:28 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
And I agree, the Pontiac motor has way too much in to it to only make 650 horse. Thank you!!
[Re: AndyF]
#3223789
03/30/24 08:29 PM
03/30/24 08:29 PM
Posts: 700 Southern Alberta
Uberpube
Southern Alberta
Yeah I have serious doubts about that carb design. I would be interested in the back story on the engine design. Peak power is 5900 RPM but the valvetrain and the oiling system appear to be NASCAR type stuff. 7/16 pushrods, Crower rocker arms. Peterson R4 pump, etc. Those are serious high dollar parts. Even the water pump uses a NASCAR style multigroove belt. Maybe it is just designed to look like a NASCAR engine? Could be going into a vintage NASCAR chassis for track days or something. Also has a Wilson bling spacer, real money was spent.
[Re: dvw]
#3223872
03/30/24 11:52 PM
03/30/24 11:52 PM
Posts: 2,498 PA
moparacer
PA
What type of carb booster? are we looking at? Doug Booster? That looks like a derivative of Pro Systems old SV1 carb. I mean, trying to reinvent the wheel sometimes doesn't work when the wheel was invented 5500 years ago. If something was better, it would have been figured out long ago. Same with boosters. All this time with annular, dogleg, straight leg, forget all that.... Just drill some holes in a tube!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: A990]
#3223977
03/31/24 12:30 PM
03/31/24 12:30 PM
Al_Alguire
Las Vegas
An "aerosol" carb. Design has been around for years and not very successful IMO and certsainly not the best way to make power.
[Re: AndyF]
#3224019
03/31/24 02:47 PM
03/31/24 02:47 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Motor Trend and Westech Dyno are a platform to showcase advertisers' products. I remember Horsepower TV around 2012 Built an Edelbrock headed hydraulic roller cammed 440 six pack that made a whopping....410hp. Seems they want us to pay attention to the bling but not the power it makes.
Keep old mopars alive.
[Re: AndyF]
#3224064
03/31/24 04:44 PM
03/31/24 04:44 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ve dynoed motors with various versions of the KRE hi-ports. One thing that seems a bit odd to me is the cam selection. You’d think big split and wide lsa would have been used to help extend the power band, yet it’s peaking at only 5900. Seems more like a street EFI type cam to me.
For sure, the hp doesn’t really seem commensurate with the total scope of the build……. At least in my mind.
[Re: fast68plymouth]
#3224071
03/31/24 05:10 PM
03/31/24 05:10 PM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
For sure, the hp doesn’t really seem commensurate with the total scope of the build……. At least in my mind. Thats the same head I sent you for testing on your flow bench correct ???
[Re: BSB67]
#3224109
03/31/24 08:40 PM
03/31/24 08:40 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
And I agree, the Pontiac motor has way too much in to it to only make 650 horse. Thank you!! Thank you again. Yes the cam is very strange. Good bit of lift but way short on duration (especially for the cubes) and wide lsa
