Re: '68 A-body dash pads
[Re: topside]
#3223569
03/29/24 05:53 PM
03/29/24 05:53 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Are they one-year-only because of the lower pads ? My A-bodies so far have been '70-up, except for a '68 Barracuda (with the lower pads). I seem to recall that the '68 upper pad extended further down than my '70-up Dusters. Wondering if a '67 upper pad interchanges with a '68. 68 is unique. There is a portion at end that sort off interlocks/fit in the lower section. When you put a 69-76 you will see pinching. 67 profile is unique, but it will physically interchange with 69-76.
[Re: topside]
#3223606
03/29/24 10:10 PM
03/29/24 10:10 PM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
People have tried to cut the ends and make the 69-76 work, but it always looks like crap. ABC Moparts is making the 68 pads now...
JB Rhinehart, Realist
A-Body's RULE!
[Re: topside]
#3223672
03/30/24 10:32 AM
03/30/24 10:32 AM
Rhinodart
Rhinotruck
Rhinotruck
I have a couple 68 pads that each have one small crack in them, can't easily tell on the one. I would let either one go for $250...
A-Body's RULE!
[Re: topside]
#3223783
03/30/24 07:47 PM
03/30/24 07:47 PM
autoxcuda
So Cal
PG classics made pads at one point. Used to be under $500.
Still make them?
