Cuda shaker intake height #3222428
03/23/24 09:30 PM
03/23/24 09:30 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
Hopefully this edelbrock single plane intake will work with a standard shaker hood. I believe a base is available for the larger afs carbs, but I am not sure about the height.
Edit: According to Barton's website it is the same height and will work with the factory shaker.... I guess I will find out in a few months.
Re: Cuda shaker intake height [Re: Craig J] #3222587
03/24/24 07:22 PM
03/24/24 07:22 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Edelbrock says it will work with a shaker
2011 Drag Pak Challenger
Re: Cuda shaker intake height [Re: Craig J] #3222884
03/26/24 01:01 PM
03/26/24 01:01 PM
central il.
second 70 Offline
second 70  Offline
central il.
Just a warning I run a Stage V on mine which is a little taller than factory and it sits higher through the hood than factory. It's as high as it can go and also as low as the base on the engine possible.
When I switched to a MSD Pro billet distributor I had to modify the base so it would fit.
Re: Cuda shaker intake height [Re: Craig J] #3222887
03/26/24 01:06 PM
03/26/24 01:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I am running Indy EZ's on my 1970 RB with a Shaker hood. They elevate the height of the intake enough to make things pretty tight once the hood is closed. In response to that height increase, I have milled the carb flange on the intake to reduce the height. Another consideration I thought about doing is to shim the K-member downward 1/4", which I did not resort to.
I'm now switching the 3 2bbls I was running to a single 4bbl throttle body to upgrade to EFI. I bought replica steel Shaket base plate for the 4bbl and will cut and weld the baseplate to adjust the assembled height of the Shaker Scoop as well as adjusting the angle it sits at.
