Eddy AirGap / Speedmaster Air Gap #3222532
03/24/24 01:17 PM
03/24/24 01:17 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
340 application. Any appreciable difference between the two, besides where they're made ?
Obviously Speedmaster's cheaper, and apparently a knock-off of the Edelbrock.
Curious about casting finish, power, and fit.
Allegedly, either will fit under a stock '67-'76 A body hood, likely needing a drop-base air cleaner.
Re: Eddy AirGap / Speedmaster Air Gap [Re: topside] #3222555
03/24/24 03:29 PM
03/24/24 03:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I wouldn’t pick the Speedmaster intake for a 340. I ported one and sold it and I’m about positive it’s more like a copy of the LD4B intake as it had small runners. They should have copied the LD340
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Eddy AirGap / Speedmaster Air Gap [Re: pittsburghracer] #3222557
03/24/24 03:36 PM
03/24/24 03:36 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks - good to know about the runners.
Engine's a pretty basic street/strip deal that's likely to get better heads than the iron Js on it now.
Likely to get a bigger cam than the current "Comp 280-degree" (that's all I know so far) it has now, too.
Re: Eddy AirGap / Speedmaster Air Gap [Re: topside] #3222564
03/24/24 03:51 PM
03/24/24 03:51 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
There is an LD340 on Abodies for sale.
America First!
Re: Eddy AirGap / Speedmaster Air Gap [Re: topside] #3222574
03/24/24 05:11 PM
03/24/24 05:11 PM
PA.
"Little"John
"Little"John
PA.
Here’s some testing I did years ago.
https://board.moparts.org/ubbthread...7021/ld-340-flow-bench-test-results.html
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
