Re: finally built some drive on ramps...........
[Re: J_BODY]
#3222548
03/24/24 02:29 PM
03/24/24 02:29 PM
Posts: 19,405 north of coder
moparx
A necessary pita….. so many tasks that are nicer to perform with jackstands NOT in the way. Assuming the square of the base is still rock solid with the additional height. Noted those holes in the bracket at the rear by the ramps….. is there an additional cradle that mounts there to secure the wheel? very solid, as the base measures 12 wide by 14 long. the extra holes at the rear are for bolt on wheel stops like are at the front, which are welded fast. the first time drive up those was somewhat nerve wracking, as the angle of the ramps is steeper that what i had expected, even though they are four feet long. the length was what worked out with what material i had in the pile. i stopped at several intervals to get out and measure the ramps for any deflection. there was none. even though i jumped around a lot, and tried to weld so the deflection was minimal when the weld cooled, i still had a built in "bow" in both ramps. al in all, i'm pretty satisfied with how they turned out, and it sure beats having the floor pan only an inch from your face like most all available ramps position it.
[Re: moparx]
#3222563
03/24/24 03:48 PM
03/24/24 03:48 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
How do you get it to go up that high of a ramp? I have trouble sometimes with my cars pushing a standard ramp when trying to go up them.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3222670
03/25/24 12:15 PM
03/25/24 12:15 PM
Posts: 141 Missouri
randavis
Missouri
How do you get it to go up that high of a ramp? I have trouble sometimes with my cars pushing a standard ramp when trying to go up them. Me too.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: randavis]
#3222690
03/25/24 01:17 PM
03/25/24 01:17 PM
moparx
How do you get it to go up that high of a ramp? I have trouble sometimes with my cars pushing a standard ramp when trying to go up them. Me too. for my car with the converter stall it has, a steady power brake of 2000rpm was the ticket. it took a couple of tries to figure out the best way, but that method worked like a charm, and the car smoothly drove up the incline with no drama whatsoever. it sure was intimidating though !
[Re: MadMopars]
#3222692
03/25/24 01:27 PM
03/25/24 01:27 PM
moparx
I'm not an engineer, nor did I stay at a Holiday Inn last night. However, my thoughts are there should be an "X" brace or similar on the open sides of the stand. I could be wrong. I just thought it was worth considering. as a fabricator with almost 46 years of my working career dedicated to design and fabrication, i thought that as well. however, the top made from 1"x1 1/2", 1/8" wall tubing, plus the 3/16"x1 1/2" angle on the open side at the bottom made it seem unnecessary. i tested that "theory" by turning them on their sides, and placing the front of my caravan on them to see if they racked out of square. i may add an "x" or a diagonal in the future.
[Re: racerx]
#3222883
03/26/24 12:59 PM
03/26/24 12:59 PM
moparx
How much does one of those weigh? that is a great question, as i never weighed them. with that said, my feeble old a$$ can pick them up [each piece separately, of course ] without too much difficulty, although i can tell there is some heft there. if i were to hazard a guess, 40-45lbs for each piece maybe ? i know for sure they are way heavier than those cheap tin ramps that everybody has !
[Re: moparx]
#3222899
03/26/24 01:44 PM
03/26/24 01:44 PM
Posts: 4,070 Mo.
racerx
Mo.
How much does one of those weigh? that is a great question, as i never weighed them. with that said, my feeble old a$$ can pick them up [each piece separately, of course ] without too much difficulty, although i can tell there is some heft there. if i were to hazard a guess, 40-45lbs for each piece maybe ? i know for sure they are way heavier than those cheap tin ramps that everybody has ! Be careful
[Re: moparx]
#3222906
03/26/24 01:56 PM
03/26/24 01:56 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Nice! And I forgot how cool that car is
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3223110
03/27/24 12:19 PM
03/27/24 12:19 PM
moparx
thanks Zippy ! when i finally got it running again late last year, i played around with the tune a little, and it helped quite a bit. i'm going to play with it more this year in hopes of a slight improvement. one thing i have done lately, is repair the [very] crusty inner fender under the battery box. even though the car only has almost 19k original miles, the batteries over the years have played the devil on the battery tray and inner fender. i found a [way] smaller battery that has a bunch of cranking amps, so i made a new battery tray from stainless, and incorporated it into the inner fender repair. i know the purists will be offended, but this car is really not anything special, and my ownership began with me buying it as a "total" back in 1970 when i worked at a body shop. since it got back on the road after being repaired, it has never been "stock", so i don't mind modifying it whenever i feel like it. especially since under my stewardship, i have beat on it every chance i get. i also ordered a new driveshaft from action machine. 3 1/2" .083 wall with solid 1350 joints. i'll find the next weak link, then reinforce it. last year, i replaced the steel wheel/dog dish setup on the front with american 5 spoke wheels, and that really changed the cars look. this year, new carpet [the old original stuff is just old and turning to dust], drive shaft and front loop [loop ready to install] and possibly new rear wheels. the next caretaker will REALLY hate me if he wants to restore the car, but oh well !
