Re: Parts washer solvent recommendations
[Re: Dabee]
#3222229
03/22/24 07:15 PM
03/22/24 07:15 PM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
have always used safety-kleen solvents. Yes they cost a little more but it last three times longer and cleans better. Had my parts washer since the early '80's. I've used a lot of different solvents in it over the years. Odorless paint thinner was always the least expensive. However, prices have skyrocketted over the past - let's say ten - years so I've switched to Saf-T-Kleen solvent becuase itssimilarly priced and doesn't seem to evaporate as quickly. It also has a higher ignition temperature so there's that aspect of ot too. FWIW, I always put a plastic trash bag in the drum before adding the solvent. Every few years I pump out the solvent leaving a little bit with all the crap in the bag which I take out and dispose of. This way I don't have to clean the drum every time I replace/add solvent.
[Re: Stanton]
#3222262
03/22/24 09:31 PM
03/22/24 09:31 PM
Posts: 15,424 Omaha Ne
TJP
Omaha Ne
have always used safety-kleen solvents. Yes they cost a little more but it last three times longer and cleans better. Had my parts washer since the early '80's. I've used a lot of different solvents in it over the years. Odorless paint thinner was always the least expensive. However, prices have skyrocketted over the past - let's say ten - years so I've switched to Saf-T-Kleen solvent becuase itssimilarly priced and doesn't seem to evaporate as quickly. It also has a higher ignition temperature so there's that aspect of ot too. FWIW, I always put a plastic trash bag in the drum before adding the solvent. Every few years I pump out the solvent leaving a little bit with all the crap in the bag which I take out and dispose of. This way I don't have to clean the drum every time I replace/add solvent. good idea on the plastic bag. I started leaving the lid down on mine and found it really slows the evap rate
[Re: TJP]
#3222266
03/22/24 09:44 PM
03/22/24 09:44 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
That stuff is great but makes my hands feel like 600 grit for a few days ( removes finger print oil) LOL ... and solvent doesn't ?!?!?
[Re: TJP]
#3222270
03/22/24 10:29 PM
03/22/24 10:29 PM
Posts: 5,361 Rancho Cordova, California (Sa...
hemi71x
I'm assuming you wear gloves? That stuff is great but makes my hands feel like 600 grit for a few days ( removes finger print oil)
Yes, i always do. Ya, it can do a number on your hands if your skin can't tolerate it.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Stanton]
#3222439
03/23/24 11:24 PM
03/23/24 11:24 PM
TJP
Omaha Ne
That stuff is great but makes my hands feel like 600 grit for a few days ( removes finger print oil) LOL ... and solvent doesn't ?!?!? Not that I've noticed the part that amazes me is it's supposedly biodegradable 😲
