Cast aluminum wheel lug hole repair #3221366
03/19/24 08:58 AM
03/19/24 08:58 AM
Confusion
Dodger440 Offline OP
Confusion
Does anyone have a recommendation for someone who can do a good job at repairing a damaged tapered seat lug nut hole in a cast aluminum wheel? I have 2 of the Kelsey Hayes recall wheels that have a couple lug holes that I would like fixed before I restore the wheels. The damage isn't bad. I see there are press in seats available made for this type of repair, but I would rather have them welded up and remachined by a competent shop that will get it right. Thanks!
Re: Cast aluminum wheel lug hole repair [Re: Dodger440] #3221420
03/19/24 12:39 PM
03/19/24 12:39 PM
moparx Offline
moparx  Offline
while not being able to offer any suggestion on who to send the wheel to for a repair, i have often drilled out the buggered up taper seat and reamed to a common "shank style" nut found on aftermarket mag wheels.
this almost always requires the shank style nuts to be drastically shortened [in a lathe] so they do not bottom out on the drum/disc before becoming fully tightened.
sometimes, however, the taper on that style of wheel can be touched up with a 60 degree "chamfer bit" as is commonly used in a machine shop.
can you post a picture of the wheel in question ?
beer
Re: Cast aluminum wheel lug hole repair [Re: moparx] #3221461
03/19/24 03:37 PM
03/19/24 03:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Not a welder, but I've read on a bicycle website years ago that welding on aluminum can make it get softer so it may need heat treated afterwards.
I would seek out a repair shop that does wheel repair for high end cars like Vipers, Vettes, etc. and see what they tell you.
Re: Cast aluminum wheel lug hole repair [Re: moparx] #3221541
03/19/24 09:33 PM
03/19/24 09:33 PM
Confusion
Confusion
beer
Thanks for the replies! Because of what these wheels are and what they are going on, I can't change to a shank style lug nut because the lug nuts need to all be the same and also be correct. I took a couple pictures of 1 of the damaged holes. It is a little worse than the picture makes it look. I believe there are 4 total holes (not all on the same wheel) that need a little repair.
Re: Cast aluminum wheel lug hole repair [Re: Dodger440] #3221555
03/19/24 10:14 PM
03/19/24 10:14 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
By the pics it looks like some holes are elongated.
Is that some/all of the issues?
Re: Cast aluminum wheel lug hole repair [Re: PhillyRag] #3221604
03/20/24 08:25 AM
03/20/24 08:25 AM
Confusion
Confusion
Yes, that is the issue with most of them. One hole has had a prior repair which was not done very well, so that one needs a little more work which will require machining the back surface (the part that goes up against the brake drum) to make it flat.
Re: Cast aluminum wheel lug hole repair [Re: Dodger440] #3221633
03/20/24 11:05 AM
03/20/24 11:05 AM
K
Kiddart Offline
Kiddart  Offline
K
i am not a metallurgist, but could you just have the holes drilled and then press in a hardened sleeve to the original size? I would think this could strengthen the area as well.
Thank you
Kiddart
Re: Cast aluminum wheel lug hole repair [Re: Kiddart] #3221662
03/20/24 01:24 PM
03/20/24 01:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Good idea - hardened sleeves are available at good hardware stores.
And a little skill with a small grinding wheel would handle the backside of the wheel.
Hard to tell, but are those Exciters or Vectors or ?
Re: Cast aluminum wheel lug hole repair [Re: topside] #3221675
03/20/24 02:20 PM
03/20/24 02:20 PM
moparx Offline
moparx  Offline
by the looks of that seat, i would try to touch it up with a 60 degree champher tool first.
beer
Re: Cast aluminum wheel lug hole repair [Re: topside] #3221713
03/20/24 05:40 PM
03/20/24 05:40 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
He said that they were the "Recall Wheels" , the factory ones from 1969.
That's why he's trying to fix them.
Re: Cast aluminum wheel lug hole repair [Re: SNK-EYZ] #3221761
03/20/24 08:17 PM
03/20/24 08:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ah, yes - sorry, I blew past that. Definitely worth saving !
Re: Cast aluminum wheel lug hole repair [Re: Kiddart] #3221806
03/20/24 10:32 PM
03/20/24 10:32 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That way the stud threads wouldn't dig into the softer alum, of the hole.
Machining shouldn't be that difficult.
Seems easier then trying to do alum. welding.
Re: Cast aluminum wheel lug hole repair [Re: Dodger440] #3221848
03/21/24 08:58 AM
03/21/24 08:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Cast aluminum wheel lug hole repair [Re: J_BODY] #3221894
03/21/24 12:47 PM
03/21/24 12:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You could sleeve the holes BUT you'd be losing a significant amount of the original tapered surface which is what retains the wheel - the sleeve would just be filling the hole.
The wheels should center properly on the hub since they are "Mopar" wheels. I wouldn't worry too much about the elongated holes, they don't look that bad - would probably look worse after the repairs !! I'd just make sure when installing them that they are snugged down gradually and that they center on the taper of the nuts.
Re: Cast aluminum wheel lug hole repair [Re: Stanton] #3221937
03/21/24 05:07 PM
03/21/24 05:07 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
These are the wheel inserts that should probably be used.
Picking the correct size one would be the main thing.
The wheels need machined already so getting them machined for the inserts would make sense.
https://customwheelaccessories.com/browse-our-catalog/wheel-inserts
They would eliminate the problem of the wheels wearing at the taper ever again.
They're available from multiple places.
http://www.prestigewheel.com/RetaiWheelInserts.asp
Re: Cast aluminum wheel lug hole repair [Re: SNK-EYZ] #3221950
03/21/24 06:34 PM
03/21/24 06:34 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Be nice to have the wheel center off the axle register also.
Re: Cast aluminum wheel lug hole repair [Re: B1MAXX] #3222009
03/21/24 09:57 PM
03/21/24 09:57 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If done properly with the inserts put in the correct position it would be.
The wheel should be hub centric, and the wheel inserts should position the lug nuts properly if machined and installed and placed correctly.
If done properly the hub centers on the axle flange and all the lug nuts have to do is hold the wheel securely in place.
That's how it was designed.
Wallowed out lug holes will never secure the wheel properly, hence the installation of the inserts.
Re: Cast aluminum wheel lug hole repair [Re: SNK-EYZ] #3222047
03/22/24 07:25 AM
03/22/24 07:25 AM
Apollo, PA.
Apollo, PA.
Looked like to me they weren't hub centric like a magnum 500. shruggy If they are that would be best. They make shims for that was all I was suggesting.
Re: Cast aluminum wheel lug hole repair [Re: B1MAXX] #3222160
03/22/24 03:18 PM
03/22/24 03:18 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The place in the first link I posted also has the hub centric rings to make wheels hub centric.
https://customwheelaccessories.com/hub-centric-rings
Re: Cast aluminum wheel lug hole repair [Re: SNK-EYZ] #3222163
03/22/24 03:23 PM
03/22/24 03:23 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I agree. I think that would be a much better solution.
