Re: Cast aluminum wheel lug hole repair
[Re: Dodger440]
#3221420
03/19/24 12:39 PM
03/19/24 12:39 PM
Posts: 19,383 north of coder
moparx
while not being able to offer any suggestion on who to send the wheel to for a repair, i have often drilled out the buggered up taper seat and reamed to a common "shank style" nut found on aftermarket mag wheels. this almost always requires the shank style nuts to be drastically shortened [in a lathe] so they do not bottom out on the drum/disc before becoming fully tightened. sometimes, however, the taper on that style of wheel can be touched up with a 60 degree "chamfer bit" as is commonly used in a machine shop. can you post a picture of the wheel in question ?
[Re: moparx]
#3221541
03/19/24 09:33 PM
03/19/24 09:33 PM
Posts: 179 Confusion
Dodger440
Confusion
while not being able to offer any suggestion on who to send the wheel to for a repair, i have often drilled out the buggered up taper seat and reamed to a common "shank style" nut found on aftermarket mag wheels. this almost always requires the shank style nuts to be drastically shortened [in a lathe] so they do not bottom out on the drum/disc before becoming fully tightened. sometimes, however, the taper on that style of wheel can be touched up with a 60 degree "chamfer bit" as is commonly used in a machine shop. can you post a picture of the wheel in question ? Thanks for the replies! Because of what these wheels are and what they are going on, I can't change to a shank style lug nut because the lug nuts need to all be the same and also be correct. I took a couple pictures of 1 of the damaged holes. It is a little worse than the picture makes it look. I believe there are 4 total holes (not all on the same wheel) that need a little repair.
[Re: PhillyRag]
#3221604
03/20/24 08:25 AM
03/20/24 08:25 AM
Dodger440
Confusion
By the pics it looks like some holes are elongated. Is that some/all of the issues? Yes, that is the issue with most of them. One hole has had a prior repair which was not done very well, so that one needs a little more work which will require machining the back surface (the part that goes up against the brake drum) to make it flat.
[Re: Dodger440]
#3221633
03/20/24 11:05 AM
03/20/24 11:05 AM
Posts: 1,550 Michigan
Kiddart
i am not a metallurgist, but could you just have the holes drilled and then press in a hardened sleeve to the original size? I would think this could strengthen the area as well.
Thank you Kiddart
[Re: topside]
#3221713
03/20/24 05:40 PM
03/20/24 05:40 PM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
^^^ Good idea - hardened sleeves are available at good hardware stores. And a little skill with a small grinding wheel would handle the backside of the wheel. Hard to tell, but are those Exciters or Vectors or ? He said that they were the "Recall Wheels" , the factory ones from 1969. That's why he's trying to fix them.
[Re: Kiddart]
#3221806
03/20/24 10:32 PM
03/20/24 10:32 PM
Posts: 1,754 Phila
PhillyRag
Phila
i am not a metallurgist, but could you just have the holes drilled and then press in a hardened sleeve to the original size? I would think this could strengthen the area as well. That way the stud threads wouldn't dig into the softer alum, of the hole. Machining shouldn't be that difficult. Seems easier then trying to do alum. welding.
[Re: Dodger440]
#3221848
03/21/24 08:58 AM
03/21/24 08:58 AM
Posts: 13,187 aZLiViN
J_BODY
aZLiViN
[Re: B1MAXX]
#3222009
03/21/24 09:57 PM
03/21/24 09:57 PM
SNK-EYZ
A Red State
Be nice to have the wheel center off the axle register also. If done properly with the inserts put in the correct position it would be. The wheel should be hub centric, and the wheel inserts should position the lug nuts properly if machined and installed and placed correctly. If done properly the hub centers on the axle flange and all the lug nuts have to do is hold the wheel securely in place. That's how it was designed. Wallowed out lug holes will never secure the wheel properly, hence the installation of the inserts.
[Re: B1MAXX]
#3222160
03/22/24 03:18 PM
03/22/24 03:18 PM
SNK-EYZ
A Red State
Looked like to me they weren't hub centric like a magnum 500. If they are that would be best. They make shims for that was all I was suggesting. The place in the first link I posted also has the hub centric rings to make wheels hub centric. https://customwheelaccessories.com/hub-centric-rings
[Re: SNK-EYZ]
#3222163
03/22/24 03:23 PM
03/22/24 03:23 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
These are the wheel inserts that should probably be used.
I agree. I think that would be a much better solution.
